Thread: N/A vs S/C radiator size or type
Results 1 to 5 of 5
  1. #1 N/A vs S/C radiator size or type
    May 2012
    Bloomington, IN
    Is there any difference between the GP N/A radiators or the S/C ones? Please let me know, got a guy that's willing to let go of one, and he thinks it only fits the S/C models, thanks in advance.
  2. #2 Re: N/A vs S/C radiator size or type
    Mar 2012
    NC
    I've never seen them side by side but supposedly the SC rad is thicker. I ran a NA rad for my top swapped, cammed, IC'ed car with no issues.
  3. #3 Re: N/A vs S/C radiator size or type
    May 2012
    Bloomington, IN
    So I have an '04, thicker is fine with me, I would also suppose there wouldn't be any fitment issues with either the A/C condenser in front or the radiator fans in the rear. Just want to make sure that the change is just in the core and not end tanks or attachment points or clips, thanks.
  4. #4 Re: N/A vs S/C radiator size or type
    If you buy aftermarket, likely they have one that works in either model and it's usually the thinner one.
  5. #5 Re: N/A vs S/C radiator size or type
    Dec 2012
    troll land
    Just get one from an lq1 90-97 w, theyre over an inch thick
  1. Bearing Type sound at 5-10 mph, misfire type feeling 40-50mph turning right
    By crapshoot in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-15-2014, 02:13 PM
  2. Oil Pan mounting bolt size/type
    By Blake71091 in forum General Tech Discussion
    Last Post: 04-03-2014, 07:39 AM
  3. Thread size in radiator?
    By 92bird in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-11-2013, 12:56 PM
  4. Cooler line pops out at radiator. Dealership says I need a new radiator?!?! Pic
    By nickbuol in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-27-2013, 08:27 PM
  5. radiator drain o-ring size? FAILED motormite drain.
    By alacran in forum General Tech Discussion
    Last Post: 04-03-2010, 08:16 PM
