Thread: L36 Build
Page 2 of 6 FirstFirst 1234 ... LastLast
Results 21 to 40 of 110
  1. #21 Re: L36 Build
    Dec 2012
    troll land
    Anyway im on ur side on hopping up ur l36, especially since ur gonna have it out anyway. Heres wht id get if i had to hide it, hv3(which u hav), p log etc(u also have), l67 tb, 1.9 rockers, l67 coils, and gasket match heads and intake
  2. #22 Re: L36 Build
    Jul 2012
    Chicago
    Don't hop up the L36. Even with a cam you won't be faster than an L67. And an L67 is slow these days. Don't waste your money.
    All my mods and porting and my car is slow as ****.
    -Carl
  3. #23 Re: L36 Build
    Half the point of a cam on a N/A car is just to make it sound nasty.
    The GT2 is tiny as well.
    I'd suggest a budget build.
    Trim your runners yourself, run an L26 UIM, port your heads yourself, port match the LIM, and just drive it.
    Total investment would be low, but it'd be reliable as you'd eliminate the plastic UIM and LIM gasket.
  4. #24 Re: L36 Build
    Banned
    Feb 2014
    Grand Blanc/ Flint
    The gt1 can be ran stock. But can the gt2?
  5. #25 Re: L36 Build
    Banned
    Feb 2014
    Grand Blanc/ Flint
    I have the hv3 getting plog got a 2.5dp gt1 or gt2?
  6. #26 Re: L36 Build
    Quote Originally Posted by TimMcCallum View Post
    Haven't the faintest clue what that means.
    What do you want from the car? A sorta misfire sorta lope sound or a hearty lope?
    Lope: http://www.youtube.com/watch?v=rv8qAXlLrIw
    Epic misfire: http://www.youtube.com/watch?v=hh0NS8FWCr8
    Either way, as someone else mentioned, even if you don't know cars, you'll know something is different, and you might "get in trouble" anyways.
  7. #27 Re: L36 Build
    Banned
    Feb 2014
    Grand Blanc/ Flint
    I want the deep hearty sound. That open header car with some flowmaster 40s would sound so mean
  8. #28 Re: L36 Build
    Banned
    Feb 2014
    Grand Blanc/ Flint
    What needs to be done to run the gt2?
  9. #29 Re: L36 Build
    Some springs that aren't stock.
    But so would a GT1.
    Go look at ZZPs page. The lobes they chose, LSA and advance are all part of the part number. They also list out the lobe lift, duration etc.
    They both have the same lift, but the GT2 has a bit more duration, lower LSA and no advance.
  10. #30 Re: L36 Build
    Banned
    Feb 2014
    Grand Blanc/ Flint
    I want the gt2. It says it can be ran on all stock stuff. But should play it safe with the gt1
  11. #31 Re: L36 Build
    I wouldn't run stock valve train with a cam.
  12. #32 Re: L36 Build
    If you spin your engine out with a cam, on stock springs with a couple hundred thousand miles on 'em, you're asking for trouble.
  13. #33 Re: L36 Build
    Banned
    Feb 2014
    Grand Blanc/ Flint
    Do what
  14. #34 Re: L36 Build
    Basically what he is saying is that over time the stock springs wear out when using a cam, any cam. You have to remember not to believe ZZPs propaganda. Just get some 90# springs they are cheep and should hold up pretty good with a small cam like the gt1
  15. #35 Re: L36 Build
    That stuff was written when the cars were new. Now they're very old, broken and worn out.
  16. #36 Re: L36 Build
    Banned
    Feb 2014
    Grand Blanc/ Flint
    So 90# springs and thats i?
  17. #37 Re: L36 Build
    Not that this hasn't been covered a thousand times:
    Cam basics: Change the valve seals, valve cover gaskets, valve cover grommets, LIM gasket, UIM gasket, inspect UIM for failure and replace if damaged, front timing cover gasket. Also good time to RTV up your pan gasket, check/change the lower engine/trans mount. Also check the water pump for signs of seepage and turn by hand to feel for bearing issues.
    All of the aftermarket springs are LSx springs and thus need LSx style retainers.
    Always put a new timing chain and damper on( unless you're going double roller). If you go double roller, make sure the crank gear actually matches the crank gear from your engine. All of the timing sets are sourced from Australia where they have different crank gears, thus the kits don't fit the North American engines properly.
  18. #38 Re: L36 Build
    I would also replace the retainers. And if possible the valve seals. Or what he said^^^^
  19. #39 Re: L36 Build
    Banned
    Feb 2014
    Grand Blanc/ Flint
    So gt2 cam, 90# springs, retainers, seats.
  20. #40 Re: L36 Build
    No what Matt said.
    Just buy this and get kit 4 and get a timing chain http://shop.zzperformance.com/store/...stall-Kit.aspx
  1. Replies: 399
    Last Post: 08-17-2016, 01:35 PM
  2. Build all you can build S/C 3800
    By MrPhotographer06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-30-2013, 12:01 AM
  3. Too Slow, Time for a build (GEN V/N*/L32 Lim build)
    By AmericanSoldier in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-13-2012, 01:54 PM
  4. 280-340 HP build
    By patturlington in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-11-2011, 02:33 AM
  5. New build.
    By TheOtherNick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-15-2010, 05:44 PM
