Thread: Engine Swap and now getting code P0341 andP0107
Results 1 to 4 of 4
  1. #1 Engine Swap and now getting code P0341 andP0107
    Jan 2014
    capac, MI
    I just completed an engine swap on a 2002 Grand Prix. I used a 1998 bonneville as the donor motor. It fired right up and runs decent, but keeps throwing a P0341 and a P0107 code. I read that you have to do a Camshaft position sensor reprogram. How do you do this? I swapped all sensors, except this one! Help!!
  2. #2 Re: Engine Swap and now getting code P0341 andP0107
    You'd need scan tool of sorts to do a crank/cam relearn.
    And the p0107 is map sensor code, look into that further.
  3. #3 Re: Engine Swap and now getting code P0341 andP0107
    Jan 2014
    capac, MI
    Is there anyway to program wihtout scan tool? I only have a code reader. Would it be safe to drive to a repair shop to get it done?
  4. #4 Re: Engine Swap and now getting code P0341 andP0107
    as long as its running and not stalling out your fine to drive it to a shop for a re learn.
  1. Replies: 15
    Last Post: 01-25-2013, 03:05 PM
  2. P0341 help!
    By DanGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-13-2012, 10:53 AM
  3. Engine Starts then dies after L36 Engine Swap! Help needed!
    By millertime2800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-18-2012, 10:50 PM
  4. Spartans Engine Swap (Engine Damage Pics on Front Page!)
    Last Post: 05-05-2010, 12:50 AM
  5. P0341 OBD-2 code
    By icolex1 in forum General Tech Discussion
    Last Post: 02-22-2009, 10:19 PM
