Thread: What's this plug telling me
Results 1 to 3 of 3
  1. #1 What's this plug telling me
    SE Level Member Sevex's Avatar
    Aug 2012
    Utah
    Swapped in my rockers and ls6 springs today and got a bit worried after pulling my plugs out. All 6 have a reddish tint on the porcelain And some white specks on them. My first thought was burning coolant, but there is nothing in the oil and because I was paranoid I did a leak down test on all cylinders and all showed between 5-6% leakage which leads me to believe its not head gaskets. What do you guys think? Right now they are stock heat range, unknown miles on them ( had the car for about 15k miles) and the only mods up till today are SD headers, everything else is bone stock. Let me know what you think.
    04 CompG, 1.9 rr, 90# springs, modded SD headers, 42.5#.... intercooler/3.0 mps coming soon.
  2. #2 Re: What's this plug telling me
    HUDSON
    From a distance view, the plug looks normal, the red you see on it could be from fuel additives.
  3. #3 Re: What's this plug telling me
    SWPA
    Do you use octane booster? That has been known to turn plugs red. (And it doesn't work)
  1. 2008 Base model plug and plug wire swap
    By MS1227 in forum 04+ Specifics
    Last Post: 12-06-2012, 06:14 PM
  2. Replies: 13
    Last Post: 10-12-2012, 08:01 AM
  3. stock antenna plug to universal plug?
    By kind153 in forum Audio, Security & Visual Electronics
    Last Post: 01-08-2012, 10:25 PM
  4. PCM not telling car to shift till later
    By bloxmagic in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-08-2010, 05:43 PM
  5. GM should be telling all of us thanks.
    By 16MustangVet in forum General Tech Discussion
    Last Post: 06-04-2009, 10:53 PM
