Thread: Problems with Driver Information Center
Results 1 to 11 of 11
  1. #1 Problems with Driver Information Center
    Sep 2012
    Cedar Rapids, Iowa
    My driver information center on my 02 GP GT is the one with the four settings. MPG, oil life, range and fuel used. The oil life and fuel used work just fine. However the MPG and range just read 0 and don't change even after resetting, filling up the fuel tank, etc. I unplugged it and blew into the connections, made sure all the wires are snug and everything looks fine. Car isn't giving any error codes. Anyone know why it might be doing this?
  2. #2 Re: Problems with Driver Information Center
    Dec 2008
    Lawndale, CA
    Have you checked the connections to the OBD 2 port as well as the one that goes behind the cluster? If everything is good, it is possible the DIC is bad.
  3. #3 Re: Problems with Driver Information Center
    Enfield, CT
    Check fuses and wires deeper down the harness for the DIC. Test the wiring too
  4. #4 Re: Problems with Driver Information Center
    Sep 2012
    Cedar Rapids, Iowa
    There's fuses for the DIC? And what is the OBD 2 Port?
  5. #5 Re: Problems with Driver Information Center
    Enfield, CT
    Yes and the OBD 2 port is where the scan tool hooks up to get live data on your car's PCM. OBD 2 = On Board Diagnostics version 2 and PCM = Powertrain Control Module. The OBD 2 port is right underneath the ride side of the kick plate on the driver side.
  6. #6 Re: Problems with Driver Information Center
    Sep 2012
    Cedar Rapids, Iowa
    My cluster isn't hooked up as of right now, long story. But the MPG and everything was working while it was not hooked up. It was not until just recently that it stopped giving me the info. And I checked the OBD 2 port it's fine.
  7. #7 Re: Problems with Driver Information Center
    Sep 2012
    Cedar Rapids, Iowa
    Could this be caused by the engine speed sensor?
  8. #8 Re: Problems with Driver Information Center
    Enfield, CT
    you mean Vehicle Speed Sensor? Do you have any CELs?
  9. #9 Re: Problems with Driver Information Center
    Sep 2012
    Cedar Rapids, Iowa
    Yeah that's what I meant. No I don't, does that rule out a VSS problem?
  10. #10 Re: Problems with Driver Information Center
    A VSS problem would be a whole different problem. You'd have issue even driving the car then.
  11. #11 Re: Problems with Driver Information Center
    Sep 2012
    Cedar Rapids, Iowa
    It kind of lurches when shifting gears sometimes and the cruise control doesn't work. Those are the two most common things I found when looking up failed VSS. No other major issues came up.
  1. Driver Information Center
    By SuperSE in forum General Tech Discussion
    Last Post: 03-20-2013, 05:40 PM
  2. Dim Driver Information Center
    By ljmonnin12 in forum General Tech Discussion
    Last Post: 02-13-2012, 09:25 PM
  3. driver information center
    By bc1 in forum General Tech Discussion
    Last Post: 12-12-2010, 10:21 AM
  4. Driver information center
    By sbrutcher in forum Introductions/Noob Questions
    Last Post: 02-13-2010, 03:20 PM
