Thread: Bad MAF sensor?
Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
  1. #21 Re: Bad MAF sensor?
    Mar 2014
    United States
    Would that also happen to have anything to do with the fuel usage. Today I drove 40 miles, highway, and it went thru a quarter tank... I am almost down to the E and have only driven 220 miles since the last fill up.
    thanks guys
    kov
  2. #22 Re: Bad MAF sensor?
    Mar 2014
    United States
    Also, there is no engine light, but there was a stored codes, which did include o2 sensors, can that cause such dramatic fuel use increase, a change that seemed to happen over night?
    thanks
    kov
  3. #23 Re: Bad MAF sensor?
    What code? Iac can affect gas mileage
  4. #24 Re: Bad MAF sensor?
    Enfield, CT
    O2 codes? Your gas is horrible because of that. Also, when you replace the IAC, you need to drive the vehicle for awhile so the valve can reset it's position
  1. 0 KR rear sensor & 5-7 degrees KR front sensor
    By Elite6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2013, 08:06 PM
  2. O2 Sensor not working... P0171 new sensor still no data from O2?
    By Z34Phoenix in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-16-2012, 12:20 PM
  3. question about low coolant sensor,fuel level sensor,and the
    By spider4 in forum General Tech Discussion
    Last Post: 11-26-2011, 09:19 AM
  4. camshaft sensor or crank sensor?
    By Viper in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-06-2010, 04:43 PM
  5. Picture request of Coolant Temp Sensor and TPS sensor parts
    By David A Smith in forum Shops and Community Heroes
    Last Post: 06-11-2010, 11:05 AM
