Thread: Chasing Idle Bounce!!
Results 1 to 6 of 6
  1. #1 Chasing Idle Bounce!!
    May 2013
    Carthage
    I've been dealing with an annoying idle bounce issue for a while now, it will jump quickly 200-300 rpms (sharply), not sure what this quick idle bounce indicates but here are all the things I've tried so far.....
    New:
    TPS
    IAC VAlve
    Cleaned MAF w/ MAF crc cleaner
    Cleaned Entire Throttle Body
    Spark Plugs
    Spark Plug wires
    LIM Gasket with new aluminum design by felpro
    UIM Gasket w/ new Plenum by Dorman (did check for having both o rings on the pcv valve)
    Fuel Filter
    Air Filter
    Performed Idle and throttle relearn procedure after all work...
    I've tried spraying carb cleaner around motor while idling and really couldn't find any noticeable difference anywhere...
    I did check over the vacuum lines and some rubber elbows are not in the best shape....
    Anyone know where I can buy all brand new vac lines for my 2000 Grand Prix 3.8l??
    Somebody else wanna chime in on what other possibilities i'm looking at??
  2. #2 Re: Chasing Idle Bounce!!
    sounds like a vac leak. move the vac lines while spraying them, that kind of surge sounds like a evap leak off the tb, the fat hose.
  3. #3 Re: Chasing Idle Bounce!!
    May 2013
    Carthage
    Ok I will check that tomorrow, you know where to get brand new vac lines for our prixs scottydog?
  4. #4 Re: Chasing Idle Bounce!!
    dealer, or make your own from parts store vac line and T's. parts store is like 5 to 6 bucks.
  5. #5 Re: Chasing Idle Bounce!!
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Autozone, you can get a bunch of vac line and T's cheap.
    2012 F150 STX
    - Gonna be a race truck
  6. #6 Re: Chasing Idle Bounce!!
    advance has better T's. auto zone had was that huge ass 3 inch T that sucks.
  1. Chasing a p0171
    By hensleya1 in forum General Grand Prix Discussion
    Last Post: 06-24-2013, 04:40 PM
  2. Chasing a rough idle
    By Burbman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-07-2012, 09:07 PM
  3. Chasing stupid ABS light
    By FordMan77 in forum General Tech Discussion
    Last Post: 09-22-2012, 01:00 AM
  4. Chasing P0171 again
    By GTP in RTP in forum General Tech Discussion
    Last Post: 11-14-2011, 08:00 AM
  5. ltft chasing
    By shawnrandolph in forum PCM Tuning
    Last Post: 08-31-2011, 10:53 AM
