Thread: Engine set code for EGR valve and 02 sensor simultaneously. Idles very rough.
Results 1 to 10 of 10
Threaded View
  1. #4 Re: Engine set code for EGR valve and 02 sensor simultaneously. Idles very rough.
    SE Level Member KZOO3800's Avatar
    Nov 2010
    Kalamazoo, MI
    Issue resolved. New EGR valve installed. Hate to have paid a shop for this but they fixed all issues I had noted in this thread. Markup on this part was absolutely incredibly effing high FYI. Then there's diagnostics/labor on a $87 part and you can pretty much deduce the dollar amount of rape I subjected myself to by letting a shop do this. Recent promotion at work prevented me from doing this myself because sadly I've been too busy to even look at a wrench lately. All OBDII codes clear now. 02 sensor code was for heater circuit only. Try as I might to understand why the 02 sensor heater code was set I just haven't had time to worry about it again until it returns.
    *EDIT*
    I could really use a code-scanner for situations like this one. I just need something basic. Any suggestions? Thanks.
  1. Engine Code Still On After Replacing Crankshaft Position Sensor
    By SlyBlackDragon in forum General Tech Discussion
    Last Post: 08-15-2013, 09:28 PM
  2. Engine Idles Fine, Kills when I Hit the Gas
    By Liquid86 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-24-2013, 04:18 PM
  3. Replies: 5
    Last Post: 05-29-2013, 02:15 PM
  4. Engine won't start or idles rough at above 180 degrees after its been shut off.
    By deathjunior in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-26-2012, 09:57 PM
  5. 2000 GTP Idles rough
    By TCo22 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-09-2012, 07:54 PM
