Thread: Rusty Coil Terminal??
Results 1 to 6 of 6
  1. #1 Rusty Coil Terminal??
    May 2013
    Carthage
    About a year ago while replacing spark plugs and wires, I noticed that the #2 cylinder coil terminal was rusted bad. I replaced the coil pack and went on my way, now a year later I already notice that same #2 cylinder is starting to rust again?? Could a bad ignition control module cause this, also trying to diagnose a surging idle issue.....
  2. #2 Re: Rusty Coil Terminal??
    Antioch, IL
    Put dielectric grease in your boots and on your terminals.
    check vac lines
    2009 Challenger SRT8
    Expert at being gay.
  3. #3 Re: Rusty Coil Terminal??
    Enfield, CT
    I've put dielectric grease in the boots and on the terminals on my Gf's 03 GP and those ****ers keep rusting. I keep having to sand them down. Wondering if I should replace them
  4. #4 Re: Rusty Coil Terminal??
    GT Level Member lewis1952's Avatar
    Sep 2013
    tulsa okla
    try a different brand of coil
  5. #5 Re: Rusty Coil Terminal??
    Get new wires.
  6. #6 Re: Rusty Coil Terminal??
    May 2013
    Carthage
    Thats the thing I put dielectric grease on all terminals when I replaced the plugs and wires with brand new AC delco wires and plugs.....all other coil terminals are fine but cylinder #2 keeps rusting, I'm thinking it doesn't have anything to do with moisture getting in it when the same coil terminal is rusting, even after replacing coil brand new, I'm leaning towards an ignition control module causing this, Might try replacing that and see if my surging idle issue goes away as well...
  1. Too rusty?
    By 02NavyBlue in forum General Grand Prix Discussion
    Last Post: 05-10-2013, 08:28 PM
  2. Goofy negative terminal lock on battery
    By laferri2 in forum 5.3L V8 (LS4)
    Last Post: 10-16-2012, 03:24 PM
  3. Battery terminal replacements?
    By Pure2sin in forum General Tech Discussion
    Last Post: 06-26-2012, 10:52 PM
  4. Is this terminal?
    By LePrix in forum Visual/Body Modifications
    Last Post: 10-31-2011, 06:39 PM
  5. Battery terminal
    By Bueller in forum Audio, Security & Visual Electronics
    Last Post: 12-08-2009, 02:33 PM
