Thread: Help me identify O rings in UIM/LIM gasket kits!!
Results 1 to 3 of 3
  1. #1 Help me identify O rings in UIM/LIM gasket kits!!
    May 2013
    Carthage
    Hi I'm about to replace my upper and lower intake manifold gaskets on my 2000 Pontiac Grand Prix and wanting to know exactly where all these o rings are supposed to end up BEFORE I rip it all apart..........these are the two kits I purchased to do the job....if someone can help me to identify each o ring, that would be awesome!....I want to do it once and do it right!
  2. #2 Re: Help me identify O rings in UIM/LIM gasket kits!!
    May 2013
    Carthage
    With the Felpro LIM gasket kit on the left.....it looks like there's a thermostat gasket and o ring, six bottom fuel injector o rings, the aluminum lower intake manifold gaskets, four side rails, BUT I'm confused where the two orange o rings go and the other two different size black o rings???
    With the dorman UIM gasket kit on the right....it looks like there's a plenum gasket with black tube attached to the gasket, 12 o rings (assuming 6 for the bottom fuel injector and 6 for upper fuel injectors), a EGR valve gasket, a thermostat w/ new o ring, the blue o ring looks to go between the throttle body and plenum, BUT unsure where the large orange o ring goes and the two other equal sized black o rings???
    Also, on a side question does the tube that is attached to the plenum gasket, does it get installed anywhere inside the plenum??
    THanks to anyone and everyone ahead of time!
  3. #3 Re: Help me identify O rings in UIM/LIM gasket kits!!
    St. Louis
    Should be 2 orings for the PCV valve. One small one that fits over the actual valve, then a larger one that goes in the UIM where the cap screws over it.
  1. What are these 2 o-rings? (from gasket kit)
    By BlackGT97 in forum General Tech Discussion
    Last Post: 02-20-2013, 01:03 AM
  2. HELP! LIM Gasket, Injector O-rings, Valve Cover Gaskets.....
    By Jones in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-17-2012, 12:40 AM
