Thread: Valve spring question..
Results 1 to 10 of 10
  1. #1 Valve spring question..
    Sep 2013
    California
    Hey guys I'm about to start doing some upgrades but I was trying to find out, how much hp gain can someone get with the a valve spring upgrade from a 75lb to a 105lb..
  2. #2 Re: Valve spring question..
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Springs don't add HP, you usually only change them when doing cam/rockers.
    Sent from my Galaxy Tab 3 8.0
    2012 F150 STX
    - Gonna be a race truck
  3. #3 Re: Valve spring question..
    Well your getting valve float at higher rpms.. The difference will not be noticeable by your butt dyno.
    04 Comp G.
  4. #4 Re: Valve spring question..
    Sep 2013
    California
    So it would just pull harder then???
  5. #5 Re: Valve spring question..
    Sep 2013
    California
    Oh ok.... I'm going with some 1.9 rockers and I didn't know if the valve springs added any hp
  6. #6 Re: Valve spring question..
    No
    Your not going to ever reach that point on a n/a set up unless your going turbod and all out.
    Save your money...just doing springs is going to do nothing for you at the point.
    04 Comp G.
  7. #7 Re: Valve spring question..
    Aug 2013
    McDonald PA
    No
    save your money and dont mod an NA car unless its gonna be for forced induction
  8. #8 Re: Valve spring question..
    Nov 2011
    NY
    I would suggest reading up a bit more on combustion engines and how to increase HP... Not a shot at ya', but its best that you do, in order to prevent wasting time and money with disappointing results. There are no quick pills that'll magically create HP, there are only certain things to do. And the golden rule always applies...
    CHEAP/FAST/RELIABLE
    put your finger over one word at a time and reveal that you can only have TWO of these at any time...
    cheap&fast is not reliable
    cheap&reliable is not fast
    fast&reliable is not cheap
    GOOD LUCK
  9. #9 Re: Valve spring question..
    Sep 2013
    California
    Quote Originally Posted by coolone View Post
    CHEAP/FAST/RELIABLE
    GOOD LUCK
    Thanks for that I never thought if it in that way... I guess I didn't give everything that I have plan.. The spring question was something that was bugging me and after research I couldn't find anything.... What I am doing is changing rockers and springs and after that is done I going to pick up some more heads and getting those done fully.... For what I am doing now I not expecting high gains but just a lil more do the wife can have her fun... I know you guys been beating me over the head but I guess it's my fault for not telling everything up front. I not worried about the money plus right now I'm about to order my shift kit.
  10. #10 Re: Valve spring question..
    Apr 2012
    Dayton, OH
    Its good doing the research and asking questions that you can't find clear answers about. You could do rockers, hv3, plog/dp, tune and it should add more pep to the car. Its N/A right? The search button on the forum is really helpful also.
    2012 F150 STX
  1. Question on valve spring
    By BlackGT97 in forum General Tech Discussion
    Last Post: 01-14-2013, 10:17 PM
  2. Valve spring compressor
    By apierce1289 in forum General Grand Prix Discussion
    Last Post: 05-04-2012, 04:26 PM
  3. Valve spring retainers for S1X cam?
    By crbquist in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-11-2011, 05:27 AM
  4. Valve Spring replacement...
    By Iron Indian in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-01-2008, 07:30 PM
