Thread: Down Pipe
Results 1 to 11 of 11
  1. #1 Down Pipe
    Dec 2012
    Canada
    I am considering a ZZP down pipe, if I were to buy a 3" catless DP will I be able to attach it to my existing Cat or should I just order the 3" Catted DP, which option is recommended?
  2. #2 Re: Down Pipe
    Donating User Odi's Avatar
    Chicago South Suburbs
    If you want to keep the cat order the one with the cat.
  3. #3 Re: Down Pipe
    SWPA
    Yeah, if you need the cat order the catted downpipe. It's what I have on my car.
  4. #4 Re: Down Pipe
    Aug 2013
    McDonald PA
    You will throw a cel for cat deficiency because it's so high flow compared to gms stock settings
  5. #5 Re: Down Pipe
    SWPA
    I didn't throw a CEL, but then again mine came with a built in "defouler"
  6. #6 Re: Down Pipe
    Yup you'll still set that code more then likely but depending on the year you can either use a o2 emulator or try the spark plug fouler trick or just get it tuned out.
    04 Comp G.
  7. #7 Re: Down Pipe
    Aug 2013
    McDonald PA
    My 5 dollar fouler off eBay works awesome
  8. #8 Re: Down Pipe
    Aug 2013
    McDonald PA
    Quote Originally Posted by Theaceofspades View Post
    Edit this post just had to order a longer close tipped on for my car. Makes no sense drove like 500 miles no code and came back last night so got another one
  9. #9 Re: Down Pipe
    Pennsylvania, USA
    If you want ot make your own fouler "mod", get a two pack ofspark plug non-foulers from an auto store and drill one out with a 1/2" drill bit. Screw the unmodified one into the spot for the second O2 sensor, the modified one into that, and your sensor into that. You may also need a rear O2 extension.
    If you have an 04-08, I wouldn't get the O2 simulator. Some people have no problems with them, others have their PCM go into a diagnostic loop until the O2 is replaced.
  10. #10 Re: Down Pipe
    Anything '01+ technically will have fueling issues unless tuned out.
    It's hit and miss.
    So it depends on what car the OP has.
  11. #11 Re: Down Pipe
    SWPA
    In the 2 years, or how ever long it has been, I have had the downpipe on my 07 my CEL has come on twice for the rear o2. I last cleared the code well over a year ago. I have gotten over 28 mpg on a highway trip. Looks like I got missed.
  1. need some help (down pipe)
    By titanfan12 in forum General Grand Prix Discussion
    Last Post: 08-10-2013, 07:02 AM
  2. Down pipe
    By mikeferrucci in forum Introductions/Noob Questions
    Last Post: 05-14-2013, 11:13 PM
  3. I just put a down pipe on my o4 gtp need help ?
    By 98gtp1000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-23-2009, 12:39 AM
  4. Down pipe
    By JB Miller in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-18-2009, 12:40 AM
