Thread: Won't start 02 Grand Prix gt 57000 miles
Results 1 to 20 of 30
  1. #1 Won't start 02 Grand Prix gt 57000 miles
    Mar 2014
    Tennessee
    I have a 02 Grand Prix gt coupe with 57000 miles I drove it a few times and parked it then went to crank it it wouldn't not start it turns over normally but just won't start the dash lights are dim oil services engine soon abs low oil lights are very very dim no cel light at all but the air bag and seat belt light is bright car has new fuel pump and filter it is getting fuel for sure but not sure about spark I hear relays kicking and something in the driver kick panel clicking help please car rides like a brand new car and it's killing me not being able to drive it I pulled the codes no codes came back
  2. #2 Re: Won't start 02 Grand Prix gt 57000 miles
    Jun 2012
    south haven mi
    How long was it sitting? Is the battery fully charged ?
  3. #3 Re: Won't start 02 Grand Prix gt 57000 miles
    Canada
    A pcm fuse maybe
  4. #4 Re: Won't start 02 Grand Prix gt 57000 miles
    Mar 2014
    Tennessee
    Sat 3 or 4 months before I got it and I check all underhood fuses but not in the glove box
  5. #5 Re: Won't start 02 Grand Prix gt 57000 miles
    Get a jump box on it, sounds like the battery is dead.
  6. #6 Re: Won't start 02 Grand Prix gt 57000 miles
    Mar 2014
    Tennessee
    Battery is a good battery
  7. #7 Re: Won't start 02 Grand Prix gt 57000 miles
    Mar 2014
    Tennessee
    when I jump start it the dash lights are still dim and the headlights still flicker
  8. #8 Re: Won't start 02 Grand Prix gt 57000 miles
    Mar 2014
    Tennessee
    And if it was a fuse what would make it blow after normal driving
  9. #9 Re: Won't start 02 Grand Prix gt 57000 miles
    bad ground or dirty battery terminals? they been cleaned off yet? or checked?
    you got 3 grounds that run to the tranny bell housing one fat bat neg cable and 2 smaller wires. make sure they are clean and tight too.
  10. #10 Re: Won't start 02 Grand Prix gt 57000 miles
    Mar 2014
    Tennessee
    I'll check that out it turns over like it's getting no spark I know it's getting fuel and pulled codes no codes appeared
  11. #11 Re: Won't start 02 Grand Prix gt 57000 miles
    Mar 2014
    Tennessee
    But what are bad ground symptoms
  12. #12 Re: Won't start 02 Grand Prix gt 57000 miles
    slow cranking, flickering lights.
    when you turn the key to start it the dash blacks out right? its supposed to. no dummy lights or nothing should be lit up when cranking the engine over.
    you try a shot of starting fluid in the intake? if it fires up for a few seconds its not getting fuel.
  13. #13 Re: Won't start 02 Grand Prix gt 57000 miles
    Mar 2014
    Tennessee
    When I crank it it turns over normally and tryied starter fluid doesn't work when you usually all the lights suppose to come on on the dash every light but mines doesn't it they are just dim very hard to see and it turns over like a regular car but not catching I think the dim lights has something to do with the starting problem
  14. #14 Re: Won't start 02 Grand Prix gt 57000 miles
    Mar 2014
    Tennessee
    And the dim lights thing happens when the key is in the on position
  15. #15 Re: Won't start 02 Grand Prix gt 57000 miles
    check for spark yet?
    try googeling for bad ignition harness symptoms see if you can find any one else with this type of problem.
  16. #16 Re: Won't start 02 Grand Prix gt 57000 miles
    Mar 2014
    Tennessee
    How would I check for spark
  17. #17 Re: Won't start 02 Grand Prix gt 57000 miles
    you can pull a plug out, put the plug wire back on, rest the bottom of the spark plug on metal to ground it, then crank the engine, the plug should spark.
    or prop a plug wire a inch over the coil, a spark should jump to the wire from the coil when cranking it.
  18. #18 Re: Won't start 02 Grand Prix gt 57000 miles
    Canada
    I had a car with a bad ground that worked like that( although mine wouldn't even crank over)......I would try running a ground wire from the motor to the body and see if that helps with the dim lights.
  19. #19 Re: Won't start 02 Grand Prix gt 57000 miles
    Mar 2014
    Tennessee
    I pulled the the cluster out and plugs 1 3 5 they appeared to be wet fouled plugs clean the plugs put them back in ran for about 4 secs then shut off if all the plugs fouled out would that cause a no start condition or just poor performance
  20. #20 Re: Won't start 02 Grand Prix gt 57000 miles
    St. Louis
    Typically would just run bad, but if enough are fouled out I could see if stopping it from running. Did you pull the rear plugs as well? They may be in the same shape. How smooth did it run when it ran for the 4 seconds? I wonder if the fuel pump isn't running after burning off the "prime".
  1. 1993 grand prix 3.4 wont start have to pump gas to start
    By lookout in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-27-2015, 05:45 AM
  2. Replies: 23
    Last Post: 06-21-2013, 12:52 PM
  3. PA: 97 Grand Prix SE 99k miles
    By JaredTocket in forum For Sale - Vehicles
    Last Post: 04-07-2013, 09:33 PM
  4. Grand Prix 07 High Miles
    By steelholder in forum General Tech Discussion
    Last Post: 04-21-2011, 08:33 PM
