Thread: Car will stall without warning
Results 1 to 7 of 7
  1. #1 Car will stall without warning
    Hamilton, Ontario
    Hello all,
    I have a Grandprix 2007 with about 150,000kms on it. The car is stalling with no warning while driving or siting still. I have had the crankshaft sensor replaced to remedy it. It still happens. There is NO error codes at all.
    Please help.
    Kind regards
    Rhys
  2. #2 Re: Car will stall without warning
    Maybe the harness going to the crank sensor behind the balancer is damaged?
  3. #3 Re: Car will stall without warning
    Dec 2012
    Where 4T65E's were born
    Well does it always start right back up? Sometimes? Or do you have to wait a bit?
    Sold.
  4. #4 Re: Car will stall without warning
    Too broken to be broke $$ ntreftz's Avatar
    May 2013
    What the hell is CENLA, Louisiana
    check for loose connection from the alternator to the fuse/relay center
    Poly Uppers, 3.5 snout, HAI, Can Tune, STB, Autolite 606 coppers, 2.5 cattless dp
  5. #5 Re: Car will stall without warning
    Jun 2012
    Ontario Canada
    Dad's 07 Buick does this, bad ground
  6. #6 Re: Car will stall without warning
    Aug 2013
    arlington, tx
    My 04 stalled out due to the MAP sensor. What other symptoms are you experiencing?
  7. #7 Re: Car will stall without warning
    Hamilton, Ontario
    It has been fixed. Bad connector on the Crankshaft sensor. Thanks for all your help everyone.
  1. Stall at Start
    By ShadowSwept in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-20-2012, 04:05 AM
  2. best stall speed for a gt
    By nascartech in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-10-2010, 10:59 PM
  3. stall
    By roadwarrior1 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-26-2009, 11:09 PM
  4. Start and Stall
    By l3enner in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-31-2009, 06:35 AM
  5. GP Wants To Stall
    By BADAZGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-25-2008, 07:41 AM
