Thread: Tensioner Pulley Supercharger Pulley the same?
Results 1 to 11 of 11
  1. #1 Tensioner Pulley Supercharger Pulley the same?
    May 2012
    Bloomington, IN
    Trying to order a replacement pulley for the belt tensioner (N/A) and I just want to make sure I don't order by mistake. Is the tensioner pulley the same as the supercharger pulley. It would appear from rockauto.com, but I want to be sure, are they the same pulley, dimensions, etc, thanks.
  2. #2 Re: Tensioner Pulley Supercharger Pulley the same?
    Too broken to be broke $$ ntreftz's Avatar
    May 2013
    What the hell is CENLA, Louisiana
    I believe its a 3.5 in pulley for the s/c belt line
    Poly Uppers, 3.5 snout, HAI, Can Tune, STB, Autolite 606 coppers, 2.5 cattless dp
  3. #3 Re: Tensioner Pulley Supercharger Pulley the same?
    # 3 is what you want.
  4. #4 Re: Tensioner Pulley Supercharger Pulley the same?
    May 2013
  5. #5 Re: Tensioner Pulley Supercharger Pulley the same?
    May 2013
    this looks very wrong...
  6. #6 Re: Tensioner Pulley Supercharger Pulley the same?
    Nov 2012
    Madison
    #3 & #8 on S/C side are regular thread, only alt. tensioner is reverse
  7. #7 Re: Tensioner Pulley Supercharger Pulley the same?
    Quote Originally Posted by spazzz View Post
    some bonnies and park ave's are reverse threads on the sc tentioner. most gp and regals are normal threads.
  8. #8 Re: Tensioner Pulley Supercharger Pulley the same?
    May 2012
    Bloomington, IN
    Gates, Dorman, or Dayco? Or does it even matter? thanks
  9. #9 Re: Tensioner Pulley Supercharger Pulley the same?
    i just got a dayco #3 for my sc tensioner pulley last month. works fine.
  10. #10 Re: Tensioner Pulley Supercharger Pulley the same?
    Mercer, Pa
    I found Mexpulley on eBay. They use NTN bearings and are metal not plastic. About $15 dollars for ribbed they should have smooth also.
  11. #11 Re: Tensioner Pulley Supercharger Pulley the same?
    May 2012
    Bloomington, IN
    Bought the Dorman pulley, they are metal and have NTN bearings as well.
  1. 98 GTP supercharger idler and tensioner pulley help
    By BillA in forum General Grand Prix Discussion
    Last Post: 09-20-2012, 09:25 PM
