Thread: MAF Sensor problem?
Results 1 to 11 of 11
  1. #1 MAF Sensor problem?
    Jan 2014
    Canada
    Hey all, i'm new here. I got an engine code the other day reading P0102. I know this is the MAF sensor so i changed it twice now and the light still won't go away. I cleared the code and hours later it comes back. Any ideas as to what i can do to fix this?
  2. #2 Re: MAF Sensor problem?
    check the wires to the plug for the maf. unplug it, then bend the wires back at the plug, look for cracks in the insulation. if you see the wire, the pig tail is bad. you can buy a new one on line for like 10 bucks. parts store sometimes carry them.
    theres a fuse for the maf also, so check your fuse boxes, in car, and under the hood.
  3. #3 Re: MAF Sensor problem?
    Dec 2013
    Take the intake air boot off of the throttle body and make sure there isnt crap on the screen. Usually happens if the bottom of the air filtet box is loose or the boot is loose and falling off the box. Also if you are going with a reman sensor i have seen many that are crap right out the box
    Sent from my SCH-R970 using Tapatalk
  4. #4 Re: MAF Sensor problem?
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    Replacing with new or used? normally 3 out of 4 from the junkyard are bad from my experience
    I went NA when a whore left -$300 in my bank account.
  5. #5 Re: MAF Sensor problem?
    i got a used one from a junk yard, its 3 years old since i got it.
  6. #6 Re: MAF Sensor problem?
    Jan 2014
    Canada
    Thanks for all the input guys, as its cold as all hell here in Canada, i'm gonna have to wait till it warms up to look into it. I noticed the other morning that it went out and it did it again this morning, but when the car heats up it comes back on, i ran the code just to be sure and it still says the MAF? It seems to go out when it's cold and come back when it warms up, i don't know if that'll help any.
  7. #7 Re: MAF Sensor problem?
    the car runs in closed loop till its warmed up, the pcm is running the car on pre set settings, once warm the pcm and sensors take over.
    check them wires, it take less then a minute to look at them.
  8. #8 Re: MAF Sensor problem?
    Jan 2014
    Canada
    Hey Scotty, I checked the wires this morning and they seem to be fine, I can't see any splits or wires so now I'm really confused
  9. #9 Re: MAF Sensor problem?
    after market mafs suck. did you ever try cleaning your old maf? or check for a blown fuse in the fuse boxes yet?
  10. #10 Re: MAF Sensor problem?
    Jan 2014
    Canada
    I replaced it with one from a junkyard here, double checked to make sure it was in good condition and everything was still intact inside. I cleaned both the replacement and original sensor with sensor cleaner thoroughly but i haven't checked the fuses yet. It's weird because with the old sensor in it would have the typical MAF sensor issue's but since i put this replacement one in it hasn't done it...
  11. #11 Re: MAF Sensor problem?
    Jan 2014
    Canada
    Okay, I checked the fuses and they're perfectly fine...
  1. New MAF Sensor - Problem
    By kamposs in forum General Tech Discussion
    Last Post: 12-31-2013, 07:54 PM
  2. MAF sensor problem?
    By 2000 Grand Prix GT Blue in forum General Tech Discussion
    Last Post: 06-03-2013, 08:26 PM
  3. MAF sensor problem
    By GTP Chic in forum General Tech Discussion
    Last Post: 05-07-2013, 02:41 AM
  4. Do I have an O2 sensor problem?
    By ronmexico in forum General Tech Discussion
    Last Post: 04-13-2012, 09:41 AM
  5. knock sensor problem??
    By colindunn in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-16-2010, 02:26 PM
