Thread: Which brand larger radiator for a 99 GT
Results 1 to 5 of 5
  1. #1 Which brand larger radiator for a 99 GT
    Dec 2008
    Lawndale, CA
    Hi guys. A brief background before I get to my question. I am currently running the 1" spectra radiator. I replaced my stock 5/8's one due to a leaking tank. Well I noticed some coolant leaking the other day from the car. I took a look and I see there is a small leak on the passenger side tank. I have had the radiator since May of 2011. I can't use the warranty which is 2 years from the date of purchase.
    Has anyone else had any issues with spectra?
    I am looking at other brands such as vista-pro, TYC and propart on rockauto. Has anyone had experience with these brands or recommend a brand? I have also looked at the ZZP 1" radiator but I am unsure of what brand they use.
    I am going to stay with the 1" size for my NA.
    Thanks
  2. #2 Re: Which brand larger radiator for a 99 GT
    Too broken to be broke $$ ntreftz's Avatar
    May 2013
    What the hell is CENLA, Louisiana
    I got the vista-pro its done well so far. the only unfortunate thing is that it was designed for the newer fan layout but it will work. the upper and lower mounts will line up perfectly but the side you may have to do some engineering
    Poly Uppers, 3.5 snout, HAI, Can Tune, STB, Autolite 606 coppers, 2.5 cattless dp
  3. #3 Re: Which brand larger radiator for a 99 GT
    Dec 2008
    Lawndale, CA
    Thanks. I took another look to trace the location of the leak. The leak is actually leaking at the upper trans line where the plastic of the fitting meets the plastic of the tank. Going to try and fix it.
  4. #4 Re: Which brand larger radiator for a 99 GT
    May 2013
    I would personally recommend replacing the radiator, rock auto has the 15/16ths core for cheap its worth replacing before it cracks after you fix it. I used a fiberglass and resin and it held for two weeks very well but it cracked again somewhere else.
  5. #5 Re: Which brand larger radiator for a 99 GT
    Dec 2008
    Lawndale, CA
    I will end up replacing it. I need to buy me a about a week until payday. For now this will be a temporary fix.
    I was just looking for feedback on other brand radiators and any feedback on others using the spectra.
  1. Radiator brand help!!!
    By Grandprix27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-20-2011, 10:04 PM
  2. Larger Oil Pan
    By apierce1289 in forum General Tech Discussion
    Last Post: 05-25-2011, 02:17 PM
  3. Larger Cam With Larger Rocker Ratio's?
    By pontiackid in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-20-2009, 02:29 PM
  4. larger injector tuning.
    By blowfishRus6 in forum PCM Tuning
    Last Post: 07-15-2009, 08:10 PM
  5. Stock scaled maf v.s. a larger maf
    By Andrew_99GTP in forum Turbo
    Last Post: 01-03-2008, 12:17 PM
