Thread: Coolant Hose Replacement
Results 1 to 4 of 4
  1. #1 Coolant Hose Replacement
    Sep 2012
    Cedar Rapids, Iowa
    I have some coolant leaking from my car. It's not coming from the water pump (although I wasn't sure at first so I replaced that as the accessory belt was making some noise and I thought it might have had a bad bearing), nor is it coming from the easily visible coolant hoses at the front of the car. It seems to be leaking from somewhere near the firewall of the car, so I was guessing it might be the coolant hoses going to the heater core. Anyone know of a good write-up of replacing those or at least know how hard it would be to replace those?
  2. #2 Re: Coolant Hose Replacement
    sounds like the plastic elbows maybe leaking. http://www.grandprixforums.net/showt...coolant+elbows
    if its the hose to the core they either un clamp with a pinch of the clamp ends, or its a after market screw clamp. take the hose off and get a new one.
  3. #3 Re: Coolant Hose Replacement
    Nov 2012
    Tennessee
    Your quick scotty...... was posted 4 mins and you had him fixed up. lol
  4. #4 Re: Coolant Hose Replacement
    Sep 2012
    Cedar Rapids, Iowa
    Thanks for your help scotty! I'll take a look at those and see if that might be the problem.
  1. Washer Fluid Hose Replacement
    By UCF04GPGTPCompG in forum General Tech Discussion
    Last Post: 09-16-2013, 11:07 PM
  2. lower rad hose replacement
    By 1filthygp in forum General Grand Prix Discussion
    Last Post: 11-26-2012, 08:25 AM
  3. Flush/Drain Coolant from Bottom Radiator Hose
    By kennn in forum General Tech Discussion
    Last Post: 07-08-2012, 03:56 PM
  4. Coolant hose
    By Fem in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2012, 03:04 PM
  5. Broken coolant hose (elbow)
    By kking89 in forum General Tech Discussion
    Last Post: 09-29-2011, 10:34 PM
