Thread: Engine knock, fearing the worst
Results 1 to 17 of 17
  1. #1 Engine knock, fearing the worst
    Oct 2011
    San Antonio
    Please watch this Youtube and let me know if this is a bad rod bearing. http://www.youtube.com/watch?v=TOlCi...ature=youtu.be
    The car is a 1999 GT with 89,000 miles (although I have often suspected odometer fraud).
    History: about 1 week ago the engine started making an odd noise like in the video. As I was shooting this video yesterday the car died and would not start again. The starter could barely turnover the motor after the stall and now it cannot turnover at all. I had the battery and starter checked at the parts store, both are good (also, there was no indication prior to this that the battery or starter were going bad). There has been no work done to the vehicle in the past year. I removed the spark plugs last night and used an inspection camera to check the combustion chamber. I didn't see anything out of the norm. With the spark plugs removed I tried cranking the motor and it wouldn't budge. Opinions/advise please.
    -Andrew B.
  2. #2 Re: Engine knock, fearing the worst
    take the belt off try to crank it. if it dont crank still, try a beaker bar on the bolt in the harmonic balancer and try to turn the engine manually.
    is that your vid? if so it dont sound good. like a rod knock.
    hows the oil look? is it over filled? milky or foamy looking?
  3. #3 Re: Engine knock, fearing the worst
    Oct 2011
    San Antonio
    K, I'll try removing the belt this afternoon. That is my vid. The oil appeared normal on the dipstick.
  4. #4 Re: Engine knock, fearing the worst
    Florida
    Unfortunately sounds like rod knock.
  5. #5 Re: Engine knock, fearing the worst
    Oct 2011
    San Antonio
    The oil is clean. Got the engine able to crank again by turning the balancer pully.
    Btw, I recently started using synthetic oil, could that have caused a rod bearing failure?
  6. #6 Re: Engine knock, fearing the worst
    just how hard did you have to pull to get it to move again? and it still wont fire back up?
    dont think the oil could cause this.
  7. #7 Re: Engine knock, fearing the worst
    St. Louis
    Unless the oil was super low. From the sound of the vid it looks like it's engine swap time. Just seems odd that it did it w/o eating coolant like we would expect especially at lower mileage. Wonder if the UIM cracked and dumped a bunch of coolant in it??
  8. #8 Re: Engine knock, fearing the worst
    Oct 2011
    San Antonio
    Not much, just turned in the opposite direction of engine rotation maybe 1/8 of a turn. It wasn't difficult but I also was using a 1/2 inch breaker bar.
  9. #9 Re: Engine knock, fearing the worst
    Oct 2011
    San Antonio
    The car started again for a few seconds but was making an awful high pitch squeal sound in addition to the knock. The engine died before I had a chance to do anything else.
  10. #10 Re: Engine knock, fearing the worst
    well, in that case put a fork in it. its done.
    that squeal was more then likely the bearing. then it locked up and stalled out again i bet.
  11. #11 Re: Engine knock, fearing the worst
    GTX Level Member Bills1997GTP's Avatar
    Oct 2012
    Philadelphia
    I'm curious to know what caused it .
    Sent from my iPhone
    2004 Grand Prix GTP 150,000 " The New Edition "
  12. #12 Re: Engine knock, fearing the worst
    Oct 2011
    San Antonio
    Quote Originally Posted by Bills1997GTP View Post
    Sent from my iPhone
    Me too. I guess I'll start checking junk yards for another 3.8. I'm assuming any 3.8 from 1997-2003 will work.
  13. #13 Re: Engine knock, fearing the worst
    Oct 2011
    San Antonio
    Got everything apart and found the culprit, spun the #5 rod bearing. I'll try to post pics tomorrow.
  14. #14 Re: Engine knock, fearing the worst
    Oct 2012
    Philadelphia
    Quote Originally Posted by huttler View Post
    Any idea on why tho?
    Sent from my iPhone
  15. #15 Re: Engine knock, fearing the worst
    Oct 2011
    San Antonio
    Below are the pictures of the blown engine. I got a used 2006 Lucerne motor with 37,070 miles from ebay (the last pic is the ebay engine). Got the engine installed and running a few days ago thanks to the great write-ups on this forum (I used billboosts engine R&R method). There was very little that had to be swapped over from my blown Series II motor to the Series III (UIM, injectors, oil filter housing). Everything is good except an odd vibration when the car comes to a stop and sometimes while turning at very low speeds.
    http://
    http://
    http://
    http://
    http://
    http://
    http://
    http://
    http://
  16. #16 Re: Engine knock, fearing the worst
    Oct 2011
    San Antonio
    Incase anyone is curious who sold me the motor for future reference (scroll down on the page).
    http://www.ebay.com/itm/ENGINE-2006-...vip=true&rt=nc
  17. #17 Re: Engine knock, fearing the worst
    Florida
    That'd a damn clean looking motor.
  1. 4th engine with rod knock
    By RideWithPride in forum General Grand Prix Discussion
    Last Post: 05-26-2013, 11:34 AM
  2. Need help engine knock??
    By thomasd2010 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-28-2012, 04:34 PM
  3. Engine Knock
    By tdm571 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-22-2011, 07:49 PM
  4. Engine knock???
    By MagnoliaMak in forum General Tech Discussion
    Last Post: 03-15-2011, 07:52 PM
  5. Need help, Engine Knock
    By valleyd01 in forum General Tech Discussion
    Last Post: 10-02-2009, 06:28 PM
