then keep that breaker bar with you at all times cause its possible that it will turn off and the teeth will fall short of a full turn to turn the engine over to fire up. aka stop turning the engine when cranking it over.
the starter teeth pull in and away from the fly wheel when its not in use, so the fly wheel wont hit it when your turning the balancer bolt to move the fly wheel a inch or 2.
