Thread: cooling issue
Results 1 to 7 of 7
  1. #1 cooling issue
    SE Level Member stlunatics2oo3's Avatar
    Michigan
    on my 3.8 NA
    i noticed the temp gauge wasnt going up as normal. (i did replace the thermostat last night just to be sure)
    after driving 20 or so miles my low coolant light came on so i checked it was low maybe a cup worth low. but the upper radiator hose was warm and the lower was way way cooler, I know a radiator is suppose to cool the coolant but it seemed way to cold. after replacing the thermostat it gets to temp way faster. my next thing is going to change the coolant elbows prolly this weekend. gotta get it done before christmas driving..
  2. #2 Re: cooling issue
    Aug 2011
    'Merica
    probably want to change the LIM gaskets too and flush the system
  3. #3 Re: cooling issue
    Feb 2013
    37.295091, -121.930053
    Make sure you have the thermostat in the correct way. It may not be opening up. Also did you change your temperature sensor as well?
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  4. #4 Re: cooling issue
    Michigan
    the thermostat is in correctly, it gets to temp fine, I was thinking of changing the temp sensor, but checked with a scan tool and the temp is right on with the gauge.. I know the lower intake has been changed based on the red rtv I can see around it lol. and nothing in coolant or oil to show signs of bad head or intake. just boggled my mind is all,
  5. #5 Re: cooling issue
    St. Louis
    Did you bleed the cooling system after changing the T-stat? Could just be air trapped in it.
  6. #6 Re: cooling issue
    Michigan
    Yeah I bled it, this issue was before the thermostat change, just didnt think the temp should be so different..
  7. #7 Re: cooling issue
    Dec 2012
    Where 4T65E's were born
    Well this is Michigan, temps are cold and much less flow is required to keep the engine cool.
    Like they mentioned check to see if you have the updated LIM gaskets, you can tell by looking in between the heads and LIM. Black means plastic faulty gaskets, and silver means you have the updated good aluminum gaskets. The reason they suggest that is because elbows are usually part of that job, so if the lim gaskets fail later you'll probably be replacing the elbows again.
    Sold.
  1. 99 cooling fan issue
    By spidyrmen in forum General Tech Discussion
    Last Post: 04-23-2013, 05:04 PM
  2. Another cooling issue. '98 N/A 3.8
    By harner in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-04-2013, 09:51 AM
  3. Cooling issue with 00 gtp
    By 3CLiPSE in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2011, 04:02 PM
  4. Cooling issue
    By stlmo_gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-22-2011, 06:43 PM
  5. cooling issue
    By mik01gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-31-2011, 10:47 PM
