Thread: 05 Grand Prix Timing Cover Gasket Replacement
Results 1 to 3 of 3
  1. #1 05 Grand Prix Timing Cover Gasket Replacement
    Jan 2013
    Phoenix
    I just pulled the front timing cover off my engine in order to fix a coolant leak.
    It took a few tricks to get the balancer off but no big deal. i'm debating on dropping the oil pan a bit when I bolt the timing cover on but hesitant to break it loose since its not leaking.
    Any of you guys just RTV it up without touching the oil pan bolts ? If so, what is the trick to not squeezing off the rtv when sliding the cover along the alignment pins ?
  2. #2 Re: 05 Grand Prix Timing Cover Gasket Replacement
    just rtv it. Make sure you use thread sealant on the bolts putting it back together.
  3. #3 Re: 05 Grand Prix Timing Cover Gasket Replacement - STARTING TO GET DIRTY
    Jan 2013
    Phoenix
    Well, it looks like my timing cover gasket replacement has turned into a bigger project.
    I found that my car has the aluminum oil pan and does not have an oil pan gasket. Instead, it has a grey RTV as a sealer.
    Since I noticed some leaks around the intake manifold, the oil pan and the rear main seal, I decided to pull the engine and replace all of them. While the engine is out, i'm replacing the trans front pump seal.
  1. Timing Cover gasket replacement
    By TEK310 in forum General Tech Discussion
    Last Post: 06-10-2013, 06:28 AM
  2. Timing cover gasket choice....
    By L36 Killer in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-17-2012, 10:15 AM
  3. timing cover gasket confusion
    By TEK310 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-23-2012, 09:37 AM
  4. Oil Pan Gasket, Crank Seal/Timing cover.
    By Nowak1981 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-17-2011, 02:48 PM
