Thread: Help! Replaced serpentine belt now car will not start.
Results 1 to 11 of 11
  1. #1 Help! Replaced serpentine belt now car will not start.
    GT Level Member firstdue's Avatar
    Toledo, Ohio
    Car died in traffic, found tensioner pulley seized and belt broken. Replaced both now car cranks....and cranks but does not fire. Need some suggestions!! Thanks!!!
    Sent from my DROID RAZR using Tapatalk
    2009.1 Liquid Red G8 GT
    2001 Grand Prix GT Bright Red
  2. #2 Re: Help! Replaced serpentine belt now car will not start.
    Maybe the belt hit the crank sensor wire harness when it broke.
    Or hit the ignition control modules ground wire on the side of the block under the coil bracket.
  3. #3 Re: Help! Replaced serpentine belt now car will not start.
    yup, follow the harness down from the coil area, look for some damage.
  4. #4 Re: Help! Replaced serpentine belt now car will not start.
    Toledo, Ohio
    Thanks guys!! Looked and don't see any obvious damage. Waiting for a tow.
  5. #5 Re: Help! Replaced serpentine belt now car will not start.
    did the belt get jammed behind the balancer by any chance? the large pulley at the bottom. if so the crank sensor may have taken a shot.
  6. #6 Re: Help! Replaced serpentine belt now car will not start.
    Toledo, Ohio
    Yes, pulled big pieces of the belt from behind that pulley. I can see the crank sensor and it appears intact.
  7. #7 Re: Help! Replaced serpentine belt now car will not start.
    ive seen members have this same problem, when its light out take a good look at the harness, the icm ground wire, if all that looks good the sensor may be dead.
    last guy whos belt broke and wrapped behind the balancer needed a new crank sensor.
  8. #8 Re: Help! Replaced serpentine belt now car will not start.
    Toledo, Ohio
    Yes, it was the crank sensor. Mechanic also said the balancer needed to be replaced. I guess the belt did some damage to it as well.
    Sucks that stuff like happens when its single digit temps outside. I like to do all my own repairs to an extent...and could probably have done this in my driveway in warmer weather.
  9. #9 Re: Help! Replaced serpentine belt now car will not start.
    storys like these make me glad i changed my chirping tensioner pulley before it let go.
  10. #10 Re: Help! Replaced serpentine belt now car will not start.
    Toledo, Ohio
    LOL, Yeah its my sons car. He mentioned as I was replacing the belt that it had been chirping..he just thought it was the extreme cold we've been having. That and some of the dash lights have been on for a couple days. Had to bite my tongue...LOL. Needless to say now he knows to mention any odd sound....or dash light.
  11. #11 Re: Help! Replaced serpentine belt now car will not start.
    it just sucks when a pulley only costs 20 bucks. a stitch in time as they say, right?
  1. Replaced serpentine belt, engine still chirping
    By ayoh482 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-12-2013, 12:46 PM
  2. Serpentine belt
    By Sudden in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-16-2012, 08:42 PM
  3. serpentine belt
    By fremmy182 in forum General Tech Discussion
    Last Post: 10-22-2010, 05:04 PM
  4. serpentine belt
    By rmil03 in forum General Tech Discussion
    Last Post: 09-01-2010, 05:44 PM
  5. serpentine belt
    By Getagrip in forum General Tech Discussion
    Last Post: 04-21-2010, 05:26 PM
