Thread: 10* of KR on 2002 GT (stock) HPT Scanner
Results 1 to 19 of 19
  1. #1 10* of KR on 2002 GT (stock) HPT Scanner
    GTX Level Member acidcrashdburnd's Avatar
    Apr 2012
    Middletown DE
    Just bought a 2002 GPGT for a daily, no rust!
    so far:
    oil/filter
    trans/filter
    o2 sensor
    plugs/wires
    I scanned it today for the first time and saw 10* KR @3940RPM (WOT). the car is 100% stock other than some stupid K&N filter the last owner put on it. The plugs I used are AC Delco Platinum
    I think I might do a power log and 2.5 inch ZZP DP then start playing with the tune.
    2005 GPGT- Top Swapped Click me! 15.5 @109
    2002 GPGT- slow and stock
    1993 Oldmobile 88
    - exploded the diff @158k
    GPF Resident Flowmaster Troll
  2. #2 Re: 10* of KR on 2002 GT (stock) HPT Scanner
    Its a stock L36, its going to knock..........alot.
    Remove those plats, and put in Iridiums. 3800's hate platinum plugs.
    Toss in a tank 91+ ocatne and you should see the KR go down some.
  3. #3 Re: 10* of KR on 2002 GT (stock) HPT Scanner
    I told you on fb to put iridiums in it and get rid of the plats
  4. #4 Re: 10* of KR on 2002 GT (stock) HPT Scanner
    Apr 2012
    Middletown DE
    I put copper 104's in and I added 2% fuel. I have never scanned a stock car before, that **** is nuts. Makes me want to do a PLOG and 2.5 DP and the crush bend where the 2nd o2 sensor is... wtf, it looks like it goes down to 1.5in back to 2.5
    1993 Oldmobile 88
  5. #5 Re: 10* of KR on 2002 GT (stock) HPT Scanner
    My wifes stock Bonneville has about 8ยบ
  6. #6 Re: 10* of KR on 2002 GT (stock) HPT Scanner
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    Why do you have 104's in when your stock?
    You want the hottest spark possible. XP606 Iridiums.
  7. #7 Re: 10* of KR on 2002 GT (stock) HPT Scanner
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    If it's high miles it could have carbon build up raising the compression ratio. Run a few cans of seafoam or similar thru the engine and check your KR again. Or if you have a really steady hand go buy a gallon of distilled water. Get a cup or something you can easily control how much water your pour. Take the maf sensor out and start the car. Hold the rpms steady at 2-3k rpms and very slowly pour the water thru the maf sensor hole. If the engine sputters badly or starts to die STOP you dont want to hydrolock your engine (These cars do a good enough job of that on their own) Once you have gone thru about 1/3 of the jug check your KR again. It should have improved some if carbon buildup is your problem.Keep repeating until the KR goes away.
    One time my dad came home with his 383 Dodge Polara Knocking like crazy. (Sounded like the worst rod knock in the world) He popped the hood and after a few gallons of water and a few hours later the knocking was gone. Carbon buildup in the cylinder had broke loose and was making the noise.
    I went NA when a whore left -$300 in my bank account.
  8. #8 Re: 10* of KR on 2002 GT (stock) HPT Scanner
    St. Louis
    The ol "trickle water down the carb" trick huh? Never tried it on a fuel injected car (except for a TB injection setup). I'd be more inclined to try the Seafoam treatment first and go from there. As long as you don't drown it shouldn't have to worry about hydrolock/bending rods.
  9. #9 Re: 10* of KR on 2002 GT (stock) HPT Scanner
    Jan 2012
    Indianapolis
    Quote Originally Posted by FordMan77 View Post
    I wouldnt think theres a difference between the carbon in a fuel injected engine vs carbon in a carbed engine. Only issue i could see would be ruining sensors thats why I said take the MAF out and it happens to make a nice little pour hole too. But I definitely agree with you that he should probably start out with trying seafoam.
  10. #10 Re: 10* of KR on 2002 GT (stock) HPT Scanner
    Apr 2012
    Middletown DE
    Quote Originally Posted by indygrandprix View Post
    why not just use some of my 50/50 meth that I have gallons of sitting around? and seafoam that goes in to the brake booster line, right? Its been a while since I have used that stuff.
    1993 Oldmobile 88
  11. #11 Re: 10* of KR on 2002 GT (stock) HPT Scanner
    St. Louis
    Quote Originally Posted by acidcrashdburnd View Post
    Yep, from what I've read
    "The best place to use it on the 3800 is the brake booster line, which is connected near the fire wall with a yellow tip. That is the only spot it can clean all the heads from"- courtesy of Hippo.
  12. #12 Re: 10* of KR on 2002 GT (stock) HPT Scanner
    Never Be A Tim. ILoveAudi's Avatar
    Aug 2012
    Middle of Nowhere, OH
    I mean, 10* is better than 11*
    1998 GTP Coupe - DIY Intake, Stock - 178k miles with rusty weight reduction (sold)
    1998 GTP Sedan - CT turbo kit, billet wheel pt61, s1x blower cam, Iceman stage 3 heads, 90# springs for all the valve floatz, walbro pump, fuel pump rewire *slowest s1x build ever*
  13. #13 Re: 10* of KR on 2002 GT (stock) HPT Scanner
    Omaha, NE
    I'm waiting for "I put on MSD coils and a bosch splice in o2 sensor".
  14. #14 Re: 10* of KR on 2002 GT (stock) HPT Scanner
    Apr 2012
    Middletown DE
    where is the damn like button, this needs to come back. I only put 104's on it because they didnt have AC Delco copper plugs or 606's in stock, well they did just not six of each. and nope Bosch plug in sensor
    1993 Oldmobile 88
  15. #15 Re: 10* of KR on 2002 GT (stock) HPT Scanner
    Possible. 606 plugs irid or copper, 93 octane and see how that does.
  16. #16 Re: 10* of KR on 2002 GT (stock) HPT Scanner
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    years ago I bought a 2.5 inch downpipe and did a u-bend delete(it was a used shorty downpipe with no u-bend delete) and a 91 octane incar tune from overkill, he said he got it to 0 knock.
    3.8l N/A POWA! :4'' HAI\L67 HVTB\HV3\ER Rockers\WP underdrive pulley\Headers\cat delete\91 octane overkill incar tune.3.69 gears, Trans go shift kit.
    My Car:http://www.grandprixforums.net/threa...2005-Impala-LS
  17. #17 Re: 10* of KR on 2002 GT (stock) HPT Scanner
    Apr 2012
    Middletown DE
    Quote Originally Posted by Grimsin View Post
    If I can find these things for cheep I might do this, but with a cat.
    1993 Oldmobile 88
  18. #18 Re: 10* of KR on 2002 GT (stock) HPT Scanner
    He "said"?
    lul.
  19. #19 Re: 10* of KR on 2002 GT (stock) HPT Scanner
    St Thomas Ontario
    yup, he did.I trust him not to lie.
  1. I need a Stock 2002 GTP.bin, HPTuners
    By Quicklynx in forum PCM Tuning
    Last Post: 11-21-2010, 01:37 PM
  2. 2002 GTP Light in stock stereo
    By 2002 GTP 40th in forum Off Topic Discussion
    Last Post: 10-06-2010, 11:58 PM
  3. pro scanner?
    By gtpinsc in forum Off Topic Discussion
    Last Post: 11-12-2008, 12:50 PM
  4. Stock GTP vs C32 AMG (2002)
    By kappy332 in forum Track Sessions and Kills
    Last Post: 10-07-2008, 08:57 AM
