Thread: 10* of KR on 2002 GT (stock) HPT Scanner
Results 1 to 19 of 19
  1. #1 Re: 10* of KR on 2002 GT (stock) HPT Scanner
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    Quote Originally Posted by FordMan77 View Post
    The ol "trickle water down the carb" trick huh? Never tried it on a fuel injected car (except for a TB injection setup). I'd be more inclined to try the Seafoam treatment first and go from there. As long as you don't drown it shouldn't have to worry about hydrolock/bending rods.
    I wouldnt think theres a difference between the carbon in a fuel injected engine vs carbon in a carbed engine. Only issue i could see would be ruining sensors thats why I said take the MAF out and it happens to make a nice little pour hole too. But I definitely agree with you that he should probably start out with trying seafoam.
    I went NA when a whore left -$300 in my bank account.
  2. #2 Re: 10* of KR on 2002 GT (stock) HPT Scanner
    GTX Level Member acidcrashdburnd's Avatar
    Apr 2012
    Middletown DE
    Quote Originally Posted by indygrandprix View Post
    why not just use some of my 50/50 meth that I have gallons of sitting around? and seafoam that goes in to the brake booster line, right? Its been a while since I have used that stuff.
    2005 GPGT- Top Swapped Click me! 15.5 @109
    2002 GPGT- slow and stock
    1993 Oldmobile 88
    - exploded the diff @158k
    GPF Resident Flowmaster Troll
  3. #3 Re: 10* of KR on 2002 GT (stock) HPT Scanner
    St. Louis
    Quote Originally Posted by acidcrashdburnd View Post
    Yep, from what I've read
    "The best place to use it on the 3800 is the brake booster line, which is connected near the fire wall with a yellow tip. That is the only spot it can clean all the heads from"- courtesy of Hippo.
  1. I need a Stock 2002 GTP.bin, HPTuners
    By Quicklynx in forum PCM Tuning
    Last Post: 11-21-2010, 01:37 PM
  2. 2002 GTP Light in stock stereo
    By 2002 GTP 40th in forum Off Topic Discussion
    Last Post: 10-06-2010, 11:58 PM
  3. pro scanner?
    By gtpinsc in forum Off Topic Discussion
    Last Post: 11-12-2008, 12:50 PM
  4. Stock GTP vs C32 AMG (2002)
    By kappy332 in forum Track Sessions and Kills
    Last Post: 10-07-2008, 08:57 AM
