Thread: Bad EGR Code P1404
Results 1 to 11 of 11
  1. #1 Bad EGR Code P1404
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    Have code P1404. From what I have read it is set when the PCM determines that the EGR is stuck partially open. It seems to come up more often as it gets colder out. I pulled the EGR off and cleaned it out, it wasn't very dirty to start with. The pintle moves up and down freely by hand and if I let it go to the closed position on its own and blow air thru it a very very very minimal amount gets by.
    So is there anything else I should be looking at doing before replacing my EGR? (I did look at all the wires going to the EGR and they look alright and I have no other codes right now except a MAF code but I fixed that.)
    I went NA when a whore left -$300 in my bank account.
  2. #2 Re: Bad EGR Code P1404
    Too broken to be broke $$ ntreftz's Avatar
    May 2013
    What the hell is CENLA, Louisiana
    I wish I had an answer for you on that, I have the same exact problem. it was happening only on cold starts and now that its getting colder its all the time, minus the rare drive cycle reset. I can delete them but it just makes the light go away, the code is seems to be pending most of the time.
    Poly Uppers, 3.5 snout, HAI, Can Tune, STB, Autolite 606 coppers, 2.5 cattless dp
  3. #3 Re: Bad EGR Code P1404
    GT Level Member lewis1952's Avatar
    Sep 2013
    tulsa okla
    You might try seafoaming your engine. As it gets colder carbon gets more brittle and breaks off easier. It only takes a tiny piece to hold the pintle open.
  4. #4 Re: Bad EGR Code P1404
    Jan 2012
    Indianapolis
    So I took the EGR off of another GP that has no check engine light and put it on my car and cleared the code and drove it around and after about 20 mins of driving it came back on. So now that i've ruled out the valve being bad and the wires running to it look OK what should my next move be. Bad PCM?
  5. #5 Re: Bad EGR Code P1404
    GT Level Member primem's Avatar
    Sep 2013
    Calgary, Alberta
    disconnect the egr connector, key to run do you have 5v ref voltage at the gray wire?
    if that good I would key off...disconnect the ecm clear and blue connectors. do an ohms check of the signal wire- ecm clear connector pin 28 to the egr connector pin c brown wire. then ecm blue connector pin 31 to the egr connector pin b brown wire.
    2004 comp g
  6. #6 Re: Bad EGR Code P1404
    Quote Originally Posted by indygrandprix View Post
    try changing the map sensor. not kidding. i had a egr code that was not giving up, many suggested changing it, and i did, along with the egr. been good so far.
  7. #7 Re: Bad EGR Code P1404
    Jan 2012
    Indianapolis
    Alright I will try that and see if changing the MAP help. I have a couple extra laying around. I also recently changed the MAF (Before i changed the EGR) wondering if the "new" (from the junkyard) maf could be part of the problem
  8. #8 Re: Bad EGR Code P1404
    Dec 2008
    Lawndale, CA
    Came across this.
    http://www.grandprix.net/forum/ubbth...&Number=143825
    My mom's 96 regal with an L36 was having the same issue. I ended up reomving the EGR and soaking the valve with seafoam to remove the built up carbon that was causing the valve from spring back and forth. I also sprayed carb cleaner through the opening where the EGR sits. That got rid of the code and the car has been running fine.
  9. #9 Re: Bad EGR Code P1404
    Sep 2013
    Calgary, Alberta
    makes sense. the map and egr 5v ref source is supplied from the same source. if the map has shorted, it will bring down the 5volt ref power to all the sensors supplied on this circuit.
    2004 comp g
  10. #10 Re: Bad EGR Code P1404
    Jan 2012
    Indianapolis
    Swapped MAP sensor with 2 others and still same issue. So now I guess i'll have to pull out the voltmeter.... Damn it lol
  11. #11 Re: Bad EGR Code P1404
    May 2013
    Any luck
  1. '99 Grand Prix GT has code 1810, yet runs great as always, so why the code?
    By McFly1999 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-03-2012, 07:52 AM
  2. P1404 - cleaning EGR valve
    By SJAndrew in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-12-2011, 01:12 PM
  3. P1404 egr code reset/fix
    By ElAlacran2010 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-02-2011, 08:33 PM
  4. Error Code P1404
    By Beaver6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-02-2011, 07:36 PM
  5. SES error codes P0102, P1404
    By camcavoy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-31-2009, 09:56 AM
