Thread: MAP sensor value @ idle
Results 1 to 3 of 3
  1. #1 MAP sensor value @ idle
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    What do you guys have for a MAP sensor value @ idle. Mine is around 10" seems a little low to me.
    I went NA when a whore left -$300 in my bank account.
  2. #2 Re: MAP sensor value @ idle
    MAP in boost or map in/hgs???
    Because you'll get 2 different readings.
    No idea what map will read for in boost as I don't monitor it that way, because its eaiser to read it in in/hgs. That reading should be roughly -19 to -20 vaccum.
  3. #3 Re: MAP sensor value @ idle
    Jan 2012
    Indianapolis
    Its a GT so it's in in/hgs,
    The car runs fine and I've swapped a few different MAP sensors in it and they all give me the same reading on the scan tool. So I guess I'll just hook up my manual vacuum gauge and see what that has to say. Maybe both sensors are bad.
  1. Hissing Noise Near MAF Sensor, Rough Idle
    By zatchmo in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-16-2013, 12:15 PM
  2. Rough Idle with intermittent idle miss
    By 99GTPMLA in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2012, 12:12 PM
  3. Running rich at idle, causing idle issues.
    By matt5112 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-22-2010, 09:16 PM
  4. High / Fast Idle - Idle Air Control motor?
    By porshuh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 11:28 AM
  5. GP won't IDLE correctly. MAF sensor?
    By AEfor3 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-23-2008, 07:35 PM
