Thread: Engine Stalled And Now Will Not Start...
Results 1 to 2 of 2
  1. #1 Engine Stalled And Now Will Not Start...
    Aug 2013
    Sunshine State
    Hello everyone. I have a coolant leak where the top radiator hose connects to the radiator. This is on the to do list as far as replacement.
    Any how, I was driving home today and the engine started to run warm. It got to around 240-250 degrees and then the motor stalled. Now the motor will not start. When I turn the engine over it sounds as though there is no compression and it will not start.
    I am thinking that the issue my be the head gasket which would explain the loss of compression. What do you guys think?
  2. #2 Re: Engine Stalled And Now Will Not Start...
    I doubt it. Pull the plugs and see if they are wet with coolant. Also check your coolant level and see if it's significantly lower than it should be.
  1. 2000 GTP Stalled and Won't Start
    By patori in forum General Tech Discussion
    Last Post: 01-21-2013, 05:18 AM
  2. Car stalled
    By tigers40 in forum General Tech Discussion
    Last Post: 07-16-2012, 06:53 PM
  3. 98 gtp 3.8L sc...stalled wont start...
    By 19GTP98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-26-2011, 05:52 AM
  4. car stalled
    By tstaller2005 in forum General Tech Discussion
    Last Post: 05-07-2011, 09:18 AM
  5. car stalled
    By GTP514 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-22-2011, 02:55 PM
