Thread: Checking PCV Valve ?
Results 1 to 5 of 5
  1. #1 Checking PCV Valve ?
    Oct 2013
    Clovis, California USA
    On the L36 with the PCV valve in the upper intake manifold, how do you check to see if the PCV valve is working?
    I read somewhere on the internet that the way you check the PCV valve is to make
    sure there is suction at the oil filler hole while the engine is running; is that true?
  2. #2 Re: Checking PCV Valve ?
    Remove the connector on the map sensor on the end of the black upper intake manifold, passenger side. There is a cap that turns clockwise and locks. Turn it counter clockwise and the valve is under a spring. There should be an o-ring on the pcv. If not..stick a finger in and retrieve it. Shake the valve lightly. Do you hear a rattle of a ball bearing in a little can? If yet.. it's good, put it back together.
  3. #3 Re: Checking PCV Valve ?
    Oct 2013
    Okay cool. I'll check that out later on today. Thanks Bill.
  4. #4 Re: Checking PCV Valve ?
    Dec 2012
    Where 4T65E's were born
    For as cheap as they are I replace them. Or if you want, clean it. I clean mine once in a while, but when I removed the stock one at 109k miles I wasn't even going to attempt to clean it. The new one gets soaked in carb cleaner for a few minutes and reinstalled every 1k miles or so if I'm already under the hood doing something else.
    Sold.
  5. #5 Re: Checking PCV Valve ?
    Grocery Getter x2 goldgp's Avatar
    redneck tennessee
    And if there is white/yellow creamy goo on it, you probably need lower intake gaskets...i know from experience
    1998 GTP Mods: Getrag 5 speed ,balanced bottom end,ARP hardware,L32 rods,Federal pistons .20 over,XP Cammed,Double roller,130# springs,and 3.4 Gen V,SSC springs,GMPP sways, C5 calipers,12 inch brakes.2000 Grand Prix SE 3.8 Mods: GT dual exaust,plog,downpipe,Transgo Shift kit,1.9 yella terra rr,strut braces,gmpp kit.Both noob tuned with HP Tuner
  1. New Car. What should I be checking?
    By nukkinfuttz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-09-2012, 06:22 PM
  2. Replies: 26
    Last Post: 08-30-2012, 04:50 PM
  3. Checking In
    By kc199 in forum Introductions/Noob Questions
    Last Post: 11-15-2011, 06:47 PM
  4. New guy checking in!
    By kc50lx in forum Introductions/Noob Questions
    Last Post: 03-30-2011, 07:35 PM
  5. FNG from MI checking in
    By 06camarodude in forum Introductions/Noob Questions
    Last Post: 03-10-2011, 12:09 PM
