Thread: Overheating Issue
Results 1 to 18 of 18
  1. #1 Re: Overheating Issue
    Dec 2012
    Where 4T65E's were born
    Well in your situation I don't think a lower t-stat will help much. As of now, a correctly operating 195° t-stat at 212° engine temp, would be just as wide open as a lower temp t-stat. Going lower is for when you want your car to run at lower than 200°. What coolant is in the car as of now? I'd flush the system and replace the t-stat with a 195°(stock temp) And did you make sure nothing was blocking the front of the radiator/condenser? It seems to be running right at the temperature that the cooling fans come on, meaning more air flow is what's keeping it cool.
    Sold.
  2. #2 Re: Overheating Issue
    Sep 2013
    Dallas, TX
    I figured running lower than 200° in Dallas heat is what I should be shooting for. As for what coolant is in right now is, last flush and refill was about 60,000 miles ago and is the orange dex-cool. But recently, with the leaks, t-stat, water pump and tension assembly replacement, it's been topped off with the prestone 50/50 and water. Nothing is blocking the radiator/condenser.
  1. Overheating issue please help
    By 98gtp86 in forum General Tech Discussion
    Last Post: 06-02-2013, 11:41 PM
  2. Overheating issue - absolutely stumped (Done almost everything)
    By Elite6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-25-2012, 03:26 AM
  3. Overheating issue
    By Below Average Joe in forum General Tech Discussion
    Last Post: 11-13-2011, 11:42 PM
  4. overheating issue
    By alreadytooken in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-29-2011, 10:28 PM
  5. overheating issue
    By doc7000 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-26-2008, 01:18 AM
