Quote Originally Posted by buschegt View Post
so where the hose is, i just followed it from the brake master cylinder. the black hose that leads to the uim and there is like a breather valve right where it connects from the uim right next to the sku tag and thats what was missing. what and where is a map sensor? is that the same as mass are flow sensor? because i see thats cracked on the top but if i push on it slightly the idle do not change
That picture doesn't work. Try uploading to an image sharing site like imageshack or photobucket. You say that valve or connector on the UIM that goes to the brake booster hose is missing?
