Thread: CV boot is dragging on the frame
Results 1 to 10 of 10
  1. #1 CV boot is dragging on the frame
    Aug 2013
    California
    my 1998 GT CV boot has been dragging on the frame. I thought it was the engine mount, but inspection shows nothing wrong. Maybe the tranmission mount? Any suggestion would be nice.
  2. #2 Re: CV boot is dragging on the frame
    Dec 2012
    Where 4T65E's were born
    Either mount being excessively worn will cause the engine to sit lover. I don't think the trans mounts are oil filled, so I don't think that would cause a large drop. How do you know it's dragging? If you saw it, you should post a pic.
    Sold.
  3. #3 Re: CV boot is dragging on the frame
    gardner,mass
    Trans mount and engine mount are both hydraulic.
    Have someone press on brake hard while in drive and have them press the throttle. Do this while in drive and in reverse, backa nd fourth. If you hear knocking or the engine is moving to much then one or both are blown.
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  4. #4 Re: CV boot is dragging on the frame
    Aug 2013
    California
  5. #5 Re: CV boot is dragging on the frame
    Aug 2013
    California
    See pic? Trams mission is at least one full inch below the frame. Transmission mount??
  6. #6 Re: CV boot is dragging on the frame
    Dec 2012
    Check the mount then, that pic is thumbnail size
    Sold.
  7. #7 Re: CV boot is dragging on the frame
    Aug 2013
    California
    Thanks to all. With your help and a DIY video my brother and I raised the engine and in about four hours Replaced three of the four motor mounts. That was totally the problem. Easier than I thought. Two man job. Good idea to pick up a bent box end 15 mm wrench. It is tight getting into the engine mount.
  8. #8 Re: CV boot is dragging on the frame
    4 hours? oh boy.....
  9. #9 Re: CV boot is dragging on the frame
    Dec 2012
    I did it by myself in about 2 hours at work(all 4 mounts, two uppers and two lowers), that was my first time but I had it clear what had to be done. Good job on fixing it though.
    Sold.
  10. #10 Re: CV boot is dragging on the frame
    Aug 2013
    California
    Thanks. I guess I forgot to say that there were four missing bolts out of the eight lower engine mount. I made two trips to the store after pulling things apart.
  1. CV boot clamp breaks off...sits to low to frame
    By AREED in forum Brakes/Suspension/Chassis
    Last Post: 08-27-2013, 01:37 AM
  2. Will a 04 Sub frame fit in my 97?
    By gtpeddie in forum General Grand Prix Discussion
    Last Post: 12-19-2012, 11:07 PM
  3. what frame
    By TheGreatSamG in forum General Tech Discussion
    Last Post: 03-10-2009, 12:09 PM
  4. sub frame
    By YoungGTP in forum Brakes/Suspension/Chassis
    Last Post: 10-22-2008, 02:48 PM
  5. Rear brakes dragging
    By DRWBRTq19 in forum Brakes/Suspension/Chassis
    Last Post: 10-01-2008, 10:44 PM
