Thread: Cat is now bad replacing down pipe....
Results 1 to 20 of 27
  1. #1 Re: Cat is now bad replacing down pipe....
    Nov 2012
    Lebanon, Ohio
    Quote Originally Posted by hensleya1 View Post
    Spike89--
    Southern Ohio doesn't have inspections anymore, E-check was one of the most unpopular things around. Save yourself the $40 and get the catless, so long as you don't mind the crispy smell coming out your tailpipe. It bolts in pretty easily as long as you aren't fighting with rusty bolts, IIRC you need a 13 or 14mm socket up front and a 15 in the back, two bolts come off on both ends, stock downpipe comes right off, put some gasket sealant on both ends, bolt the new one in, good to go.
    The front bolts are in an awkward position though, it's a PITA to get out if you're dealing with stuck bolts/don't have a good extension (like I was - a fifteen minute job turned into three hours).
    As far as tuning out the P0140 code that the car -will- throw if you have a catless, just come to the meet - I'm getting mine tuned out on that occasion, too. IIRC dsmuts was charging $20-40 per tune, correct me if I'm wrong?
    Will I need a dp with an O2 bung?
  2. #2 Re: Cat is now bad replacing down pipe....
    GTX Level Member hensleya1's Avatar
    Jun 2013
    Beavercreek, OH
    Quote Originally Posted by Spike89 View Post
    Spike89--
    Nope. I never did manage to pull the rear O2 sensor out of the stock downpipe, I just disconnected it at the wiring harness. I then pushed the wire back up where it came from (there's a covered area you'll see where the wire runs forward from the rear O2's location).
    The whole contraption is in my closet along with all the other car-related supplies, until I get around to scrapping it. Who knows, maybe with some PB blaster, a couple hits of PCP, and a psycho scream from me, I'll manage to yank that guy loose and sell it separately some day.
    I got mine from W-Body, it was actually cheaper. Get the aluminized, because at the age of most GP's it will outlast the car anyway.
    2003 GT Limited Edition 199k - The $600 winter beater.
    2004 Buick LeSabre 172k - Top Swapped, 3.5 pulley, 1.9 rockers, SLP headers... still slow...
    MAKE AMERICA FAST AGAIN!
  1. zzp down pipe
    By 2005gt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-17-2011, 01:46 PM
  2. I just put a down pipe on my o4 gtp need help ?
    By 98gtp1000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-23-2009, 12:39 AM
  3. Which down pipe should I get?
    By Baron in forum General Tech Discussion
    Last Post: 04-10-2009, 12:14 AM
