Thread: No start
Results 1 to 6 of 6
  1. #1 No start
    GTP Level Member GrandPrixgtp2000's Avatar
    Madrid Iowa
    Well my girl friends sister just got a 1998 gt coupe, it has 100,000 on the dot. The otherday my girls dad was going to drive it, but he turned the key and nothing at all. He thought it was the started, so he replaced it, and nothing, he said it acts like the shifter is in drive. The battery is good! He called me and asked what it could be, i told him i had no idea so i came here! Any help would be appreciated, thanks guys!
  2. #2 Re: No start
    battery grounds, dead battery?
    or something deeper. like a ignition harness.
    you can try to jump the starter too, turn the key to run, then jump the posts with a screw driver, if it cranks and fires up id think the ignition harness is bad.
  3. #3 Re: No start
    Madrid Iowa
    He said it started right up, so ill tell him to check the ignition harness
  4. #4 Re: No start
    if he jumped the starter and it fired up, id change the ignition harness.
    he can try banging on the column under the key, if it starts via the key after a little beating, its the harness for sure.
  5. #5 Re: No start
    Madrid Iowa
    now does the harness just hook to the ignition switch
  6. #6 Re: No start
    Sparky's Answers: 2002 Pontiac Grand Prix, Changing The Ignition Switch heres a how to.
    the harness runs from under the dash up the column to the key tumbler.
    looks like this once out of the car.
  1. 1993 grand prix 3.4 wont start have to pump gas to start
    By lookout in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-27-2015, 05:45 AM
  2. what to start getting for my 07 GXP
    By rockbassray in forum General Tech Discussion
    Last Post: 10-16-2012, 05:11 PM
  3. Oh where o where o start
    By bman in forum General Grand Prix Discussion
    Last Post: 09-16-2012, 06:35 AM
  4. where to start
    By bitterpill in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-16-2009, 10:46 PM
  5. no start
    By betsgtp in forum General Tech Discussion
    Last Post: 06-05-2009, 12:19 AM
