Thread: Best LIM Gaskets to Use on 3.8 GT
Results 1 to 3 of 3
  1. #1 Best LIM Gaskets to Use on 3.8 GT
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    I am wondering what the best LIM gaskets are to use when doing a LIM gasket Job.
    My Car is an 01 GP GT and is 100% factory w/ 175k on it if that matters
    FEL-PRO Part # MS98014T Was the most expensive ones on rockauto but that doesn't always mean they're the best. I was wondering what your experiences where. Thanks
    I went NA when a whore left -$300 in my bank account.
  2. #2 Re: Best LIM Gaskets to Use on 3.8 GT
    They just need to be aluminum, so what if the picture shows they are silver in color, you want them.
  3. #3 Re: Best LIM Gaskets to Use on 3.8 GT
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    Take your pick.. RockAuto or:
    Intense:
    INTENSE Racing: Lower Intake Gaskets (L36)
    ZZP:
    GM ACDelco - Intake Gasket #GM-89017825
    RockAuto either set:
    ACDELCO Part # 89017816
    You might want to go ahead and swap out your black plastic upper intake manifold to while you have it off. From my personal experience (which maybe 1 in a million but....) after I redid my lower intake manifold gasket set I reused my black plastic upper and ended up hydro locking my motor when I started pouring coolant in because it was cracked. If you don't want to replace your black plastic piece I'd do what's described in the thread below.
    http://www.grandprixforums.net/how-mod-lim-46931.html
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  1. gaskets!
    By IntenseFace in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-18-2012, 07:11 AM
  2. Bad gaskets?
    By RichardL12 in forum General Tech Discussion
    Last Post: 02-01-2011, 02:13 PM
  3. Where to buy gaskets?
    By trailshredder in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-23-2010, 02:50 PM
  4. LIM Gaskets
    By jmac in forum Introductions/Noob Questions
    Last Post: 11-30-2009, 02:12 PM
