Thread: Next Upgrade?
Page 2 of 2 FirstFirst 12
Results 21 to 33 of 33
  1. #21 Re: Next Upgrade?
    GT Level Member jasonball's Avatar
    Nov 2008
    ft. mitchell
    wouldn't it be easier to just do a full engine swap. in stead of worriing about the new top seating right on the old bottom.
  2. #22 Re: Next Upgrade?
    Barksdale AFB, LA
    Quote Originally Posted by jasonball View Post
    Easier? Depends on who is doing the work. Plus, there are certain benefits to using the naturally aspirated short block. Cam timing is already advanced a little, and the compression is higher.
    2009 Subaru Impreza WRX STI
  3. #23 Re: Next Upgrade?
    GTP Level Member Smokin2000gtp's Avatar
    Jul 2008
    Dekalb, IL
    I doubt there would be any problems with seating since everything just bolts right up the same way. Plus a top swap would be way way faster, a lot less trouble, and quite a bit cheaper too.
    2000 Silvermist Grand Prix GTP Coupe
    Mods-Custom Thrasher CAI|Ceramic Coated S&S Headers|3.4" pulley|ZZP S4 Blower|Powrtuner|PRJ 10.4mm wires|HIDs|F-Body brakes|Koni's and Voglant's|
  4. #24 Re: Next Upgrade?
    Chicago, IL
    So a top swap is not a sc or turbo?
  5. #25 Re: Next Upgrade?
    Barksdale AFB, LA
    Quote Originally Posted by 04gpking85 View Post
    It gives you a supercharger.
  6. #26 Re: Next Upgrade?
    Jul 2008
    Germantown, Maryland
    Essentially you're turning your car into a GTP with a top swap! There are advantages to this, as well as disadvantages.
  7. #27 Re: Next Upgrade?
    Chicago, IL
    So why not just call it a supercharger instead of a top swap? What am I missing here? Can you explain this a little simpler for people who don't understand like myself?
  8. #28 Re: Next Upgrade?
    Jul 2008
    Dekalb, IL
    Because in order to get the supercharger to work you need pretty much the whole top end of a L32 not just the supercharger.
  9. #29 Re: Next Upgrade?
    Barksdale AFB, LA
    It's not just the supercharger. It's the whole top end of the engine (heads, lower intake, throttle body, supercharger, etc) that has to be swapped. Hence "top swap".
  10. #30 Re: Next Upgrade?
    Chicago, IL
    Oh ok, so would I have to do a top swap for turbo as well?
    MSD Ignition Coils, K&N CAI, SLP Headers/Downpipe/High Flo Cat/Cat Back Exhaust, Overkill PCM, 20" Moda Rims
  11. #31 Re: Next Upgrade?
    Barksdale AFB, LA
    No.
  12. #32 Re: Next Upgrade?
    Chicago, IL
    Lets put it this way, if I add on a sc do I need to do a top swap or is it optional?
  13. #33 Re: Next Upgrade?
    Barksdale AFB, LA
    Did you read the top swap thread?
    There are two options. You can top swap (preferred method), or you can use ZZP's SS M90 kit. The major difference is whether or not you have to pull the heads.
  1. need upgrade help
    By 03renegade800 in forum Off Topic Discussion
    Last Post: 01-28-2010, 11:33 AM
  2. Here I go again, suspension upgrade
    By David99GTP in forum Brakes/Suspension/Chassis
    Last Post: 09-25-2008, 02:08 PM
  3. Computer Upgrade!!!
    By offroadfury6 in forum General Tech Discussion
    Last Post: 08-14-2008, 01:14 PM
  4. 05 brake upgrade?????
    By duane9586 in forum Brakes/Suspension/Chassis
    Last Post: 05-24-2008, 02:47 PM
  5. First upgrade...
    By DesQ27 in forum Off Topic Discussion
    Last Post: 05-13-2008, 11:13 AM
