Thread: Help with coolant loss?!
Results 1 to 8 of 8
  1. #1 Help with coolant loss?!
    GT Level Member natethegreat's Avatar
    Brookings, SD
    Well, i was out messing around with the car after i got the tourque app, and i did a 0-70 run. I pulled over after it to mess with the app some and looked up to see steam coming from my hood. I quickly shut off the car and checked the engine. It appeared that coolant had puked all over the left side of the engine bay by the reservoir. I Drove it home and kept a look at the temp and it stayed the same as it usually does, but when i got home the liquid had evaporated and there was no new liquid, at least not that i know of.
    Now im not totally sure what happened or what to do. I don't think its the water pump, but i could be wrong. It appeared that there was a small leak by the intake manifold on the block. I already checked my oil and it isn't milky. I checked the dipstick/oil cap, so im not sure if its the Intake manifold gasket. Im really not sure what it is. I have had to add coolant in the past, but it wasnt very fast..every couple of months.
    Any ideas? Any help is appreciated as this is my DD! Thanks!
  2. #2 Re: Help with coolant loss?!
    I good guess is the coolant elbow thats just there, goes from the alt bracket to the LIM.
    Maybe when you went WOT it built enough pressure to push coolant out of there, maybe the elbow has a crack.
  3. #3 Re: Help with coolant loss?!
    Never Be A Tim. ILoveAudi's Avatar
    Aug 2012
    Middle of Nowhere, OH
    I'd have to say coolant elbow as well. They can be kind of weak
    1998 GTP Coupe - DIY Intake, Stock - 178k miles with rusty weight reduction (sold)
    1998 GTP Sedan - CT turbo kit, billet wheel pt61, s1x blower cam, Iceman stage 3 heads, 90# springs for all the valve floatz, walbro pump, fuel pump rewire *slowest s1x build ever*
  4. #4 Re: Help with coolant loss?!
    x2 on blown elbow.
  5. #5 Re: Help with coolant loss?!
    Brookings, SD
    Woohoo! Thanks guys! Lets hope its that and my motor isnt ****ed!
  6. #6 Re: Help with coolant loss?!
    Aug 2012
    I can almost guarantee you that's what it is. Don't worry.
  7. #7 Re: Help with coolant loss?!
    If your motor doesn't sounds effed.. don't think it's effed. Pretty straightforward concept and one that'll help you with these motors. Plus.. they take a serious overheating to mess them up.
    Go do the elbows, report back and FWIW when a mechanic or car guy talks about a car, left is driverside and right is passenger. Think of the orientation as if you are sitting in the driverseat.
  8. #8 Re: Help with coolant loss?!
    May 2012
    la mesa, ca.
    Try and get the metal elbows. They have them on eBay if you can wait for the mail
  1. Weird Loss of coolant.
    By lanceman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-21-2011, 12:41 PM
  2. determining coolant loss
    By Jakegday in forum General Tech Discussion
    Last Post: 08-01-2010, 03:03 PM
  3. 02 gtp coolant loss
    By froggy73 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-24-2010, 10:28 AM
  4. Total coolant loss
    By Jus in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-06-2010, 06:56 PM
  5. Mysterious coolant loss ...
    By timweidner in forum General Tech Discussion
    Last Post: 03-13-2010, 09:33 AM
