Thread: Coolent elbows 1997 3800
Results 1 to 20 of 21
  1. #1 Coolent elbows 1997 3800
    GTX Level Member kjohnson's Avatar
    Nov 2008
    Harlan, IA and University of Northern Iowa
    Hey guys I just did my coolent elbows on my 03. My buddy needs it done to his 1997 Buick. Since it is a 97 is the process any different? I know the 97s are messed up so I thought I'd ask before starting
    silver 2003 Grand Prix GT List is on it's way to be updated
  2. #2 Re: Coolent elbows 1997 3800
    http://www.grandprixforums.net/how-c...ows-49779.html heres the how too, follow bills directions for the 97 and 98.
    mines a 98 the lower elbow is cast its part of the alt bracket. take the bolts out, then wiggle it a bit while pulling on it. dont wiggle to hard or the timing cover can break. once its off, clean all the holes very well, take the O ring off the new elbow, put it on the cast elbow, lube with oil slide it back on with the new upper elbow in place as well.
  3. #3 Re: Coolent elbows 1997 3800
    Nov 2008
    Soo I've removed all of the bolts on the tensioner and I can't get the thing to move. Any ideas I really don't want to break it or the piece it goes in
  4. #4 Re: Coolent elbows 1997 3800
    you can try shooting some penetrating oil at the elbow, where it enters the timing cover.
    it takes a bit of work to get it out, i also was a bit scared it would break, pull it towards the fender, and gently wiggle side to side while pulling it.
    very small wiggle, dont go twisting it too much.
    i also broke the top elbow first. that frees the top up. channel locks cracked it easy.
  5. #5 Re: Coolent elbows 1997 3800
    Nov 2008
    I can't really get it to pull twords the fender. It moves very little
  6. #6 Re: Coolent elbows 1997 3800
    Nov 2008
    There are only four bolt holes on it correct? It is really solid right now. I hit the bottom "elbow" with wd40 a few minutes ago. I haven't even gotten the collent leak worse yet. I just did this on my 03 last week and it is soooo much easier. Not near the stress of breaking something improtant
  7. #7 Re: Coolent elbows 1997 3800
    keep at it, wiggle while pulling, its all you can do, it took a few minutes to get mine off as well. ( i walked a way from it a few times as well lol) that hole gets corroded some, the O ring just dont want to come out past the crud. cleaning this hole is very important too so the new O ring seals.
  8. #8 Re: Coolent elbows 1997 3800
    Nov 2008
    Ok I'll go work some more then. I'll post back when I get it. Thanks for the advise
  9. #9 Re: Coolent elbows 1997 3800
    no problem, good luck.
  10. #10 Re: Coolent elbows 1997 3800
    Nov 2008
    Do I have to break the coolent elbow to get enough movement to get it off?
  11. #11 Re: Coolent elbows 1997 3800
    the upper plastic one will break on its own, if you dont break it first on purpose
  12. #12 Re: Coolent elbows 1997 3800
    Nov 2008
    This sucks. It's still stuck and there is really no good way to grab it to try and pull and wiggle. Ever tried heating this after some liquid wrench?
  13. #13 Re: Coolent elbows 1997 3800
    its gonna leak now with all the fiddling, keep at it.
    dont know a bout heating it, it could help, watch out for a fire with the liquid wrench on it tho..
  14. #14 Re: Coolent elbows 1997 3800
    Nov 2008
    Any ideas if the coolent elbow breaks off in the hole going into the motor?
  15. #15 Re: Coolent elbows 1997 3800
    Nov 2008
    I can feel the piece but there is no way I'm gona get it out without breaking it too. I have no idea how to break it while it is in there though
  16. #16 Re: Coolent elbows 1997 3800
    did the elbow break off the alt bracket?
  17. #17 Re: Coolent elbows 1997 3800
    Nov 2008
    It's the top elbow that goes in the engine and in the tensioner. It's the round piece that is just past the o ring. It fell into the hole just believe Pcv valve into the motor. I can't catch a break. Ps I got a lot of wiggle but I still can't get it off
  18. #18 Re: Coolent elbows 1997 3800
    you got all 3 bolts off the bracket right?
  19. #19 Re: Coolent elbows 1997 3800
    that small ring of plastic should be ok if it pushed into the lim.
    keep pulling on the lower, it will pop, you need to pull pretty hard, while keeping it square to the engine. the more it comes out the easier it will wiggle.
  20. #20 Re: Coolent elbows 1997 3800
    Nov 2008
    I got it off and got it back together! And I got the plastic. Thank you for the moral support
  1. 1997 Olds Cutlass Supreme 3800 swap
    By Sven the Sexman in forum General Tech Discussion
    Last Post: 12-06-2012, 11:13 PM
  2. 1997-2005 3800 Maintenance List
    By moddman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-09-2012, 12:32 PM
  3. 1997 gp gt 3800 no sc
    By dondon69420 in forum Introductions/Noob Questions
    Last Post: 02-15-2012, 05:30 PM
  4. Low Coolent Display?
    By darkfox1009 in forum General Tech Discussion
    Last Post: 07-28-2011, 11:34 PM
  5. leaking coolent please help
    By kjohnson in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-19-2009, 12:40 PM
