Thread: Petcock- 2000 GP GT-flush
Results 1 to 6 of 6
  1. #1 Petcock- 2000 GP GT-flush
    SE Level Member Switzersland's Avatar
    Colorado
    Looked up the the tread on draining and flushing the radiator. I used a 1/4 drive ratchet to open and drain the Pink, ran "flush" fluid and drained, filled with water to rise and thats when the petcock no longer opened with a 1/4 turn. Petcock rotates clockwise to a stop, However the 1/4 turn counter will not allow fluid to drain. I tried to force compressor air up into the drain port while turning petcock to see if it was plugged, also tried the wire poke, no luck.
    Now what.
    i was able to drain radiator w/ siphon. Coolant and water 70/30 added and car runs fine.
    what are my options in regard to this petcock trouble.
    Thanks, J.
  2. #2 Re: Petcock- 2000 GP GT-flush
    Leave it closed so that is doesnt break.
    I would then just remove the lower rad hose and drain the coolant that way.
  3. #3 Re: Petcock- 2000 GP GT-flush
    Likely being plastic it stripped on the first try. I agree with FFDP, after battling a few of these crappy things and dealing with plugged etc.. Lower rad hose everytime.
  4. #4 Re: Petcock- 2000 GP GT-flush
    Dec 2012
    Where 4T65E's were born
    I also agree with that since I did the same thing on my flush. I have an aftermarket rad, and it's got a plastic knob you turn. Well it wouldn't turn, and taking pliers to it would surely break it, so I drained using the lower rad hose.
    Sold.
  5. #5 Re: Petcock- 2000 GP GT-flush
    GT Level Member TeeWX's Avatar
    Apr 2009
    Cresco, Iowa
    I agree with what BillBoost37 has said. Petcocks on radiators never seem to work for me. (Maybe on a brand new car)
    1998 GTP : XP Cam, 3.2 Pulley, Supporting Mods<Sold>
    2001 Formula M6 : Shhhh
    2001 SSEi : New DD, Bone Stock for now
  6. #6 Re: Petcock- 2000 GP GT-flush
    The other thing.. is we are men, we want that thing drained asap..not in 15 minutes. Petcock is about 3/8" round, lower hose.. almost 2 inches. arrrr arrrrr arrrrr
  1. 2000 gtp flush radiator problem help
    By 3CLiPSE in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-08-2011, 01:36 PM
  2. coolant leak--petcock?
    By PrixAngel in forum General Tech Discussion
    Last Post: 03-26-2011, 01:08 PM
  3. How to tighten petcock?
    By firstdue in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-05-2010, 11:08 PM
  4. To flush or not to flush!
    By SlowM90 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-18-2009, 05:58 PM
  5. Broke the dang petcock..now what?
    By Z28 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-07-2009, 07:26 PM
