Thread: Engine Misfiring oddly
Results 1 to 5 of 5
  1. #1 Engine Misfiring oddly
    Jun 2013
    So yesterday i replaced a bunch of parts on my car. I put in 2 new O2 sensors, a new cat, new plugs and wires, and a new cylinder 1/4 coil pack. After I replaced those I seem to be having some major issues with my engine misfiring. I had a cylinder 4 misfire before which is why i replaced the coil pack. But now whenever I start the car up it sputters alot and whenever i give it gas it will take off, but then immediatly bog down. so its like a constant push and pull when i drive. I had a few codes that i deleted and I drove around for about 20 minutes and i havent gotten any more codes since. Is there anything you guys can think of that could be wrong with it?
  2. #2 Re: Engine Misfiring oddly
    St. Louis
    Yes. The wires could be in the wrong order. It happens a lot on these cars for some reason. Double and TRIPLE check the firing order. Cylinders 1 3 5 are in the front from left to right, and 2 4 6 are in the back from left to right (left to right as you are standing in front of the bumper).
    Other than that could be a bad ICM, bad wiring harness, or cracked spark plug. Also, what type/brand of spark plug did you install? Hopefully either a copper or stock irridium plug and NO platinums...
  3. #3 Re: Engine Misfiring oddly
    sounds like you got the wires crossed up maybe.
  4. #4 Re: Engine Misfiring oddly
    Jun 2013
    turned out to be a cracked plug on cylinder 6. thanks for the help!!!!
  5. #5 Re: Engine Misfiring oddly
    that will do it. nice job double checking stuff.
    cracked plugs happen sometimes. if you dont have a socket with a foam insert get one, it holds the plug firm in the socket, so it has less of a chance of cracking.
  1. Misfiring
    By panheadred in forum General Tech Discussion
    Last Post: 04-25-2012, 11:16 PM
  2. 1995 Grand Prix - Intermittent start - Needles jump oddly
    By Beat Club in forum General Grand Prix Discussion
    Last Post: 03-12-2012, 11:02 AM
  3. Misfiring engine need help
    By thatguy in forum General Tech Discussion
    Last Post: 01-09-2012, 06:35 AM
  4. misfiring
    By backinblackgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-20-2010, 09:22 PM
  5. Engine Misfiring @ High RPMs
    By skiderek in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-08-2010, 05:57 PM
