Thread: check engine light on
Results 1 to 20 of 28
  1. #1 check engine light on
    SE Level Member ssiebor14's Avatar
    May 2013
    Biglerville
    After I shifted it out of first and slowed down to stop I shifted back to first check engine light came on. Nothing seems wrong with the engine though
  2. #2 Re: check engine light on
    That is pretty interesting. You are manually shifting, which should not cause any codes or check engine lights. Please have the code read, let us know the code, name for the code, year and model of the car.
  3. #3 Re: check engine light on
    May 2013
    Biglerville
    97 grand prix se and I couldntbget a code off of it
  4. #4 Re: check engine light on
    Why are you shifting manually?
  5. #5 Re: check engine light on
    May 2013
    Biglerville
    That's just the way I am
  6. #6 Re: check engine light on
    If the odb 2 port didnt work, check your cig lighter fuse.
    It that is blown, it won't let that port work.
  7. #7 Re: check engine light on
    May 2013
    Biglerville
    Yeahhhhhh the cig lighter doesn't work.. how do I fix that
  8. #8 Re: check engine light on
    Dec 2012
    Where 4T65E's were born
    Well get a new 15A fuse. Fusebox is in the glove box behind the pull out compartment.
    Sold.
  9. #9 Re: check engine light on
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    *whistling*
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  10. #10 Re: check engine light on
    May 2013
    Biglerville
    I don't see I thing I just looked
  11. #11 Re: check engine light on
    Dec 2012
    It's on the right side inside the glove box. It should say something about a fusebox on the top of it, and you pull where it says it. Are the 97's the same as the 02's? I would think so.
    Sold.
  12. #12 Re: check engine light on
    May 2013
    Biglerville
    Yeah I looked dude there is nothing there the only fuse box I've seen is under the hood
  13. #13 Re: check engine light on
    The smaller cubby to right of the BIG glove box part, pulls out.
  14. #14 Re: check engine light on
    May 2013
    Biglerville
    Found it.. I don't have a 15a but you think a ten would work for right now?
  15. #15 Re: check engine light on
    10a might blow, the circuit is rated for higher than a 10.
  16. #16 Re: check engine light on
    May 2013
    Biglerville
    I guess I'd have to wait then
  17. #17 Re: check engine light on
    Check and see what other fuse use a 15a and just swap it real quick to get the code. Maybe a horn fuse or a headlight fuse or somthing.
  18. #18 Re: check engine light on
    Dec 2012
    A 10 will work perfectly fine for using a scan tool, just don't use the cigarette lighter with the 10A in place, or it may blow it.
    Sold.
  19. #19 Re: check engine light on
    May 2013
    Biglerville
    Ima have to wairlt I don't have the reader right now it's at my father in laws
  20. #20 Re: check engine light on
    So either way..we are waiting. Ask him for a 15A fuse too. BTW, if the fuse blows again..take the penny outta your cig lighter.
  1. Check Engine Light - Wont downshift, whine coming from engine
    By brandibissell in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-11-2012, 08:17 AM
  2. check engine light and lose wire in engine bay
    By Fcukit33 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-13-2011, 05:29 AM
  3. Check Engine Light
    By lemmy33 in forum General Tech Discussion
    Last Post: 11-03-2011, 04:10 PM
  4. Check Engine Light
    By WHITE02GTP in forum General Tech Discussion
    Last Post: 09-01-2008, 09:01 PM
  5. Check engine light on
    By darkwingduck in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-18-2008, 07:59 PM
