Will this cause a vacuum leak?
Does any one know where I can buy this vacuum boot and a new pcv cap? Are these dealer only items?
Yes that will cause a leak for sure. Short time fix you can wrap electrical tape around it. Not sure on that cap. Check junk yards close by.
NAPA:
NAPA AUTO PARTS
Pull off the vacuum line off and try a little super glue. Let it dry, fixed. I did the to a valve stem once that had a crack at the base.
Vacuum line. Buy a 3/8 to 1/4" piece, then a T for the two sizes of line you need to adapt down to. Fixed.
Cap, Junkyard or dorman
