Thread: Need advice on a getting a new cat
Results 1 to 9 of 9
  1. #1 Need advice on a getting a new cat
    Jun 2013
    So I'm new to this forum and I believe I am posting this in the right section. I have a 2001 Grand Prix GT and I believe its a 3.8L v6.
    I have been having some issues with my car stuttering while idling and my service engine light flashing. I have had a broken cat for years and it seems to be starting to give me trouble. So I am thinking about getting a new 2" down pipe with cat back from zzp. So here are my questions...
    1. Is zzp reliable?
    2. What are all the parts i would need to mount the 2" down pipe to the stock manifold and exhaust?
    3. Is there any maintenance I have to keep up on if I install the new down pipe?
    4. How will it affect my gas mileage?
    5. Will it have any adverse affects on my car in a few years?
    Thank you in advance!
  2. #2 Re: Need advice on a getting a new cat
    Banned
    Jan 2013
    Colorado
    Take it to the vet.
    But seroiusly, go with ZZP. They are good. I would email them for better advice.
  3. #3 Re: Need advice on a getting a new cat
    Quote Originally Posted by camopaint0707 View Post
    If you take ^^ this guys advice, make sure you get a pcm with the cat codes removed. Most of the time ZZP's "good" stuff sets the code because it doesn't meet the pcm's requirements. It's likely easier/cheaper to find someone that did headers and buy their downpipe.
  4. #4 Re: Need advice on a getting a new cat
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    You mean 2.5" downpipe?
  5. #5 Re: Need advice on a getting a new cat
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    ^^^ x2 or get a magnaflow universal cat. I paid $70 for mine I believe and never triggered a code in my 99GT
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  6. #6 Re: Need advice on a getting a new cat
    Apr 2011
    North Dakota
    Howdy 01GT guy:
    My wife has a 97 GT, I put a 2.5 inch ZZP 304 stainless pipe with cat on it because I kept getting a P0420 code. The pipe fit with no mods and wife says it made it sound better. Milage has gone up about 1 or 2 MPG.
    I was still getting the P0420 code so I did the anti-fouler trick. I had to change the O2 sensor out and used a Bosch replacement because the stock one was to large to fit the anti-fouler. Since then no more P0420 code. The truth of the matter is that the old O2 sensor may have been bad, but everything together works so I am not changing a thing.
    With the U-Bend deleat that is part of the new pipe I had to clearance the underside to fit the O2 sensor with the anti-foulers. I just used a bottle jack to dent around the sensor to make it fit.
    As far as the ZZP downpipe goes you will not find a better built one IMHO.
    Good luck
    Robert
  7. #7 Re: Need advice on a getting a new cat
    If you dont have emissions just put in a piece of strait pipe, and do the non-fouler trick.
  8. #8 Re: Need advice on a getting a new cat
    Jun 2013
    Quote Originally Posted by slick2500 View Post
    I actually totally forgot that I don't even have to do emissions. So should I get or new downpipe or by strait pipe do you just mean I should find a piece of 2"(i believe) pipe and weld it to where I delete the cat. And how exactly does the non-fouler trick work? Also if I should get a new downpipe, is there something that will fit a 2.5" to my 2"(i believe) stock maniifold?
  9. #9 Re: Need advice on a getting a new cat
    01+ cars are more sensative to cat converters than 97-00 cars because of the new cat diag inside the PCM.
    I would buy a cat converter with a warranty and weld it in yourself if you can. I just did this on my sisters car.
    Or price out a whole downpipe unit that "doesnt" run a high flow cat and install it. A highflow unit is what sets the ses off again.
    And the non fouler trick just puts the o2 sensor further away from the exhaust gases, it makes it not stick down as far inside the pipe.
  1. Need Advice
    By Ryansgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-02-2011, 05:52 AM
  2. Need Some Advice
    By Traeger2591 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-16-2010, 12:18 PM
  3. Need some advice...
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 01-01-2010, 04:52 AM
  4. I'm the New Guy, Looking for Advice
    By 98 DAYTONA in forum Introductions/Noob Questions
    Last Post: 06-04-2009, 09:47 AM
  5. HELP! New Car Need Advice
    By Blaze2009 in forum Introductions/Noob Questions
    Last Post: 05-20-2009, 04:27 PM
