Thread: Pre-College Tune Up
Results 1 to 20 of 30
  1. #1 Pre-College Tune Up
    Jul 2012
    Marengo, Illinois
    I have a 2001 Grand Prix GT, and I should be driving it to college this fall.
    Since I won't have much time to work on my car in college, and my LIM gaskets are starting to go bad, I have decided to give my whole engine a good tune up. I am focusing mainly on reliability. This car has to last me 4 years, then I can store it until I save up enough money to do something awesome with it.
    Here is what I plan to do:
    -LIM Gaskets
    -New Dorman Upper Intake manifold
    -Aluminum Coolant Elbows
    -Water Pump (since it's only $20)
    -Plugs & Wires??
    -Valve cover gaskets
    -Coolant Flush (Dexcool or something else??)
    -Transmission Flush
    -Clean MAF
    -And of course, an Oil change.
    Also sometime in the near future:
    -U-Bend Delete
    -Make a heat shield for my cone filter, or do a fenderwell intake.
    Let me know what you guys think, and if I'm missing anything I should do while I'm at it.
    Thanks,
    Jacob
  2. #2 Re: Pre-College Tune Up
    -Transmission Flush
    Change that to a Trans pan drop w/new filter and throw in a Transgo shift kit.
  3. #3 Re: Pre-College Tune Up
    Jul 2012
    Chicago
    You can use Dex, but most would suggest running the green stuff.
    Where from IL are you?
    -Carl
  4. #4 Re: Pre-College Tune Up
    GT Level Member hockeybawler's Avatar
    Oct 2011
    huntley
    I am doing the same thing on my 04 next week but while I am changing my gaskets I am throwing on a supercharger haha, I am wondering where in illinois you are too
  5. #5 Re: Pre-College Tune Up
    Jul 2012
    Marengo, Illinois
    I will definitely get a new trans filter just forgot to write that down haha. And I am up in northern Illinois, kinda by Rockford.
    Sent from my SAMSUNG-SGH-I337 using Tapatalk 4 Beta
  6. #6 Re: Pre-College Tune Up
    Banned
    Jan 2013
    Colorado
    If you are doing all the labor yourself go for it all. Maybe fuel filter too
  7. #7 Re: Pre-College Tune Up
    Jul 2012
    Marengo, Illinois
    Yes I plan on doing all of this myself. Fuel filter is a good idea. And is a shift kit a performance mod or a reliability mod? Does it accelerate or decelerate wear on the trans?
  8. #8 Re: Pre-College Tune Up
    Jul 2012
    Marengo, Illinois
    http://www.grandprixforums.net/showthread.php?t=46931 might as well do this too while I have it all apart.
  9. #9 Re: Pre-College Tune Up
    Shift kit will make your trans last longer
  10. #10 Re: Pre-College Tune Up
    St. Louis
    Don't forget to add the valve cover bolt grommets or the new gaskets will leak again. Also some black or grey RTV to seal up the 4 corners where the LIM gaskets and LIM meet.
  11. #11 Re: Pre-College Tune Up
    Banned
    Jan 2013
    Colorado
    DO you have any modifications done?
  12. #12 Re: Pre-College Tune Up
    Jul 2012
    Marengo, Illinois
    Quote Originally Posted by FordMan77 View Post
    I do have the grommets for the valve covers and the LIM Gaskets came with a little tube of black RTV.
  13. #13 Re: Pre-College Tune Up
    Jul 2012
    Marengo, Illinois
    Quote Originally Posted by camopaint0707 View Post
    Just a cone filter. Nothing fancy haha.
  14. #14 Re: Pre-College Tune Up
    Jul 2012
    Marengo, Illinois
    Any recommendations for plugs and wires? I was just going to go with AC Delco iridium.
  15. #15 Re: Pre-College Tune Up
    Those plugs are good and just get cheap wires
  16. #16 Re: Pre-College Tune Up
    Jul 2012
    Marengo, Illinois
    Got everything done on the engine Friday.
    LIM gaskets
    New UIM
    Valve cover gaskets & grommets
    Aluminum coolant elbows
    Coolant flush
    New plugs & wires
    New water pump
    And Alot of cleaning, especially the throttle body.
    I drove around for a few hours last night and everything is working perfectly. Now I just need to do my trans flush + new filter and a shift kit.
    Will I need a new gasket for the accumulator if I install a shift kit? Ive heard some people say it is reusable...
  17. #17 Re: Pre-College Tune Up
    Hopefully you did 2 oil changes after the LIM gaskets.
    And the gasket you are talking about for the transmission is metal, so re-useble.
  18. #18 Re: Pre-College Tune Up
    Jul 2012
    Marengo, Illinois
    2 oil changes? I was just going to change it once
  19. #19 Re: Pre-College Tune Up
    You are suppose to drain the oil once you finish the job, then add in new oil to rinse out the motor incase any coolant got inside the engine. Run that oil for a few miles and drop it again and put new oil and filter on. Its the best thing to do so you don't spin a bearing.
  20. #20 Re: Pre-College Tune Up
    GT Level Member Madness's Avatar
    Nov 2009
    A little late
    Job well done. If you did all of that in one day, everything must have went pretty good.
    Favorite Quote: You can't fix stupid!!
    http://www.youtube.com/watch?v=0gxKStPXyn8
  1. College books
    By MoarkatsINmuhtrailer in forum Buy/Sell Other/Misc
    Last Post: 07-18-2012, 10:12 PM
  2. State College PA Tune?
    By shawn3091 in forum Northeast
    Last Post: 06-23-2011, 07:18 PM
  3. College Kids
    By csssaint12 in forum The Rant Forum
    Last Post: 02-22-2011, 12:33 PM
  4. College kills Cars! :(
    By paulygp09 in forum The Rant Forum
    Last Post: 03-23-2010, 04:51 PM
  5. You know your a college student when......
    By speedemongtp in forum Off Topic Discussion
    Last Post: 03-15-2010, 08:53 PM
