Thread: Blew tops of pistons
Page 1 of 6 123 ... LastLast
Results 1 to 20 of 112
  1. #1 Blew tops of pistons
    GT Level Member 01GrandPrixTURBOGT's Avatar
    Dec 2011
    Decatur
    So my top swap grand prix blew up and the guy i have swapping motors for me now said that i had holes in the top of my pistons. What would cause this? I had a 3.8 pulley, zzp pcm, headers,1.9 zzp rockers, autolite 104s, and 180 thermostat. The motor i had the stuff on had 205k. Could it of just been the high mileage?
  2. #2 Re: Blew tops of pistons
    It's Slow LS1GTP's Avatar
    Sep 2012
    Clarkston, MI
    Might be a silly question for you but did you run premium or regular?
  3. #3 Re: Blew tops of pistons
    Dec 2011
    Decatur
    Premium
  4. #4 Re: Blew tops of pistons
    Sep 2012
    Clarkston, MI
    Well the mods look alright (but I'd get a second opinion) except the fact you used a canned tune.
  5. #5 Re: Blew tops of pistons
    you had tons of KR. zzp maybe the problem. aka that tune.
  6. #6 Re: Blew tops of pistons
    Dec 2011
    Decatur
    Actually it did hit 6kr but that was after it was miss firing.
  7. #7 Re: Blew tops of pistons
    Dec 2011
    Decatur
    Well my scanner would go max 3.5 kr but it would only do that sometimes. Does the kr 1 reading on an aeroforce gauge read constantly or do i need to setup up to read constantly?
  8. #8 Re: Blew tops of pistons
    Pennsylvania
    It reads constantly and updates many times per second on the standard setting.
    Sport Edition Kv5 18x8
  9. #9 Re: Blew tops of pistons
    You probably ran lean
  10. #10 Re: Blew tops of pistons
    Dec 2011
    Decatur
    Ok thanks i'd been wodering about that cause i was knock free for awhile then it would hit 3.5 kr and back to zero. Also when i would go all out when shifting into third it would stutter or miss could that be a sign of bad tune causing a lean condition?
  11. #11 Re: Blew tops of pistons
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    no kr with my zzp tune
    02 grand prix gt- L67 swap, ZZP 1.0 pcm, thrasher CAI, SLP 2.5 catback, A/C delete, 02 emulator, poly dog bone mounts, 6000k projectors with CCFL halos, 12 in slotted front rotors, ported blower and intake, evap and EGR deleted, 12" kicker cvr with 1000 watt amp, alpine cda 9886 deck
  12. #12 Re: Blew tops of pistons
    Quote Originally Posted by Erik Adam Rodriguez View Post
    every engine is different. in car tune is the best way to go about it.
  13. #13 Re: Blew tops of pistons
    Dec 2011
    Decatur
    Well im planning on a new tune but i cant afford a dyno tune right now since all this just happened and idk how to tune myself. Anyone know another can tune company i could check? Also is there a way to tell if im running lean on my scan gauge? Also any other possibilities on why i was running lean?
  14. #14 Re: Blew tops of pistons
    Get a wb and check your afr
  15. #15 Re: Blew tops of pistons
    where do you live? post up a thread looking for a tuner in your area.
  16. #16 Re: Blew tops of pistons
    Dec 2011
    Decatur
    Central Ill.
  17. #17 Re: Blew tops of pistons
    you got people all around you, fire up a thread.
  18. #18 Re: Blew tops of pistons
    Dec 2011
    Decatur
    Alright thanks for the help i hope its just a tune cause i dont want to have to go threw this again any time soon.
  19. #19 Re: Blew tops of pistons
    like dan said, you were probably running lean.
  20. #20 Re: Blew tops of pistons
    Feb 2013
    37.295091, -121.930053
    ^^ is right i had an engine with a postion that had a hole from a lean condition
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  1. 1986 Grand Prix w/ factory T Tops
    By GP007 in forum Introductions/Noob Questions
    Last Post: 04-01-2013, 04:27 PM
  2. Blew it up :(
    By shawn3091 in forum General Tech Discussion
    Last Post: 09-13-2011, 11:01 PM
  3. Burnt fluid in a trans with only 3k tops on it???
    By Kejross in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-04-2010, 09:06 PM
  4. blew up Gp AGAIN
    By kaosGP97 in forum The Rant Forum
    Last Post: 08-04-2009, 10:10 PM
  5. air bag blew up!!!
    Last Post: 07-19-2008, 03:35 PM
