Thread: Possibly a stupid question before I top swap...
Results 1 to 12 of 12
  1. #1 Possibly a stupid question before I top swap...
    May 2012
    Albuquerque, NM
    I am within the month of my top swap and at the point where I choose to do it or find a shop/mechanic to do it. My question is, do I have to drill a hole in the block and tap it? I could've sworn I read somewhere that the L36 needed that to top swap. Am I simply confused or missing that step from te above guide?
    TIA,
    Slim
  2. #2 Re: Possibly a stupid question before I top swap...
    Slim.
    I'd suggest not having anyone touch the car, including you...if you think the block needs drilled and tapped, for anything other than a broken bolt.
  3. #3 Re: Possibly a stupid question before I top swap...
    Slim, I'm not seeing an above guide.
    To topswap though, there is no drilling and tapping, unless you are going further and say modding a lim.
  4. #4 Re: Possibly a stupid question before I top swap...
    May 2012
    Albuquerque, NM
    Ok. I've been reading over multiple top swap guides and one stated that a female hole was missing in the block for one of the L67 pulley brackets. It is not mentioned in the instructions in the sticky at the top of this section. So we're back to it basically being a gasket change... I changed my L36 gaskets so I'll do it again.
    Thanks Bill, I knew it sounded suspicious.
  5. #5 Re: Possibly a stupid question before I top swap...
    I'm not buying that pulley bracket thing. Can you quote it or something..
  6. #6 Re: Possibly a stupid question before I top swap...
    May 2012
    Albuquerque, NM
    I can't even find it anymore (the walk through I read from somewhere on google). That's why I was asking, it didn't make sense.
    Again, thanks for the clarification.
  7. #7 Re: Possibly a stupid question before I top swap...
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    I just top swapped my car and all the holes for the idler pulley you are referring to are there. If you look at your motor, under your ICM bracket you'll see two threaded holes and one 10mm bold in a quasi triangle configuration. You'll remove that one 10mm bolt and trash it, and don't worry because coolant will drain from that hole. Hopefully your top swap will come with a bunch of bolts, use thread sealant when you reassemble. I assume that's the pulley bracket you are speaking of. The other "bracket" is your ICM bracket with 1 idler pulley and your tensioner pulley for the supercharger belt. No need at all to drill and tap!!!
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  8. #8 Re: Possibly a stupid question before I top swap...
    The blocks are idential.
    Minus rods/piston compression ratio.
    You probably found that info on GTPworld, GPONA, or something.
  9. #9 Re: Possibly a stupid question before I top swap...
    May 2012
    Albuquerque, NM
    Who knows. Now that I'm trying to find it I can't.
    DB, that was the area I remember it being around. Maybe that's what they were talking about.
  10. #10 Re: Possibly a stupid question before I top swap...
    Nov 2009
    Tennessee
    If that's the area, here's a pic that might help. All three bolt holes are in your block... IIRC, the two circled in red should be open on your motor. The one circled in white will have a 10mm bold in it about half an inch - 3/4 inch long. It's threaded into a coolant port so on the NA motors it acts like a plug. When you install your idler pulley you will for sure need to put thread sealant on the bolt going into the hole circled in white!!
    Hope this helps.
  11. #11 Re: Possibly a stupid question before I top swap...
    May 2012
    Albuquerque, NM
    Quote Originally Posted by slimguns View Post
    I found where I found this! It was right under my nose. See below and please help me understand as I obviously read it wrong.
    Quote Originally Posted by 02BlueGT View Post
    Idlers for Sc belt-These require bolts that aren't on the L26/L36
    It's listed under the "Parts List"
    The link: http://www.grandprixforums.net/top-s...info-7763.html
  12. #12 Re: Possibly a stupid question before I top swap...
    May 2012
    Albuquerque, NM
    I just re-read it. So the holes are there but the bolts need to be found or bought?
  1. Anxious to get this top swap done, but I have a stupid question...
    By jlgp2007nc in forum Introductions/Noob Questions
    Last Post: 03-23-2013, 08:17 PM
  2. stupid question, dont mind me.(CAI question)
    By Silversurfer Gio in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-20-2012, 10:40 AM
  3. Probably a stupid question
    By gtpzmdc in forum Audio, Security & Visual Electronics
    Last Post: 01-06-2012, 03:43 PM
  4. possibly dumb question
    By BlackGT97 in forum General Tech Discussion
    Last Post: 09-27-2011, 06:10 PM
  5. I got a stupid question...
    By sparty16 in forum General Tech Discussion
    Last Post: 04-21-2011, 12:19 AM
