Thread: Rocking motor forward
Results 1 to 6 of 6
  1. #1 Rocking motor forward
    GT Level Member Madness's Avatar
    Nov 2009
    A little late
    If I need to rock the motor forward for the back plugs, 1)Do I leave it in park if I use ratchet straps? 2)Do I leave it in park if I simply push the car forward and use the e-brake to hold the motor in place? 3)Do I leave it in park if I just pull it forward with a pry bar and use the extra hole to hold the motor in place?
    Thanks in advance. It has not been a good year for me so far.
    Favorite Quote: You can't fix stupid!!
    http://www.youtube.com/watch?v=0gxKStPXyn8
  2. #2 Re: Rocking motor forward
    Leave it in park if using ratchet strap. Do the same if using the parking brake. Or you could man up and just reach back there and change the plugs
  3. #3 Re: Rocking motor forward
    the hole in the top mount works ok, you take the bolts out of both dog bones, engine side, then just pull the engine forward by hand, stick the bolt from the dog bone in the hole to lock it forward.
  4. #4 Re: Rocking motor forward
    Nov 2009
    A little late
    Will the car "inch or move" forward with the straps?
    Thanks for the quick reply.
  5. #5 Re: Rocking motor forward
    it may, as your pulling the engine forward and turning the tires cause its in park, but we're talking inches tops.
  6. #6 Re: Rocking motor forward
    Nov 2009
    A little late
    Thanks guys, the beer is on me tonight!
  1. I feel like rocking out for 17 minutes
    Last Post: 01-07-2013, 01:43 PM
  2. tilting motor forward
    By Madness in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-19-2012, 08:26 AM
  3. So what do I have to look forward too???
    By midrange in forum General Grand Prix Discussion
    Last Post: 02-03-2012, 08:22 PM
  4. anyone rocking the inferno front lip?
    By boostedcompg in forum Visual/Body Modifications
    Last Post: 12-14-2010, 02:43 PM
  5. Tilting motor forward
    By Toasty in forum General Tech Discussion
    Last Post: 03-06-2009, 12:02 AM
