Thread: Losing coolant IMMEDIATELY after topping off radiator!! HELP!!
Results 1 to 8 of 8
  1. #1 Losing coolant IMMEDIATELY after topping off radiator!! HELP!!
    Oct 2011
    Vineland
    Ok.... 2000 Grand Prix 3.8. The coolant elbows on the tensioner pulley gave out yesterday (40 miles from home btw) once I got to work . I figured it wasn't a big deal, so I replaced them. Well ever since I replaced them, the light continuously comes on (as soon as MINUTES after i start driving), and i have gone through a lot of water in less than 24 hrs. There is no obvious leak.
    Is this a possible head gasket, or intake Manifold gskt?
    I need answers ASAP
  2. #2 Re: Losing coolant IMMEDIATELY after topping off radiator!! HELP!!
    Did you bleed the coolant out after filling it?
  3. #3 Re: Losing coolant IMMEDIATELY after topping off radiator!! HELP!!
    Oct 2011
    Vineland
    Yes.
    It looks like the intake manifold gasket gave out.
  4. #4 Re: Losing coolant IMMEDIATELY after topping off radiator!! HELP!!
    Oct 2011
    Vineland
    How hard of a job is doing the intake manifold on these 3800's? I've done it on a 350 in a GMC Yukon, and it basically sucked.
  5. #5 Re: Losing coolant IMMEDIATELY after topping off radiator!! HELP!!
    It's super easy on a 3800
  6. #6 Re: Losing coolant IMMEDIATELY after topping off radiator!! HELP!!
    I'd doubt it's the LIM's leaking that badly. I'd expect it's the UIM itself. Not a gasket.
    http://www.grandprixforums.net/97-03...ure-60667.html
  7. #7 Re: Losing coolant IMMEDIATELY after topping off radiator!! HELP!!
    Oct 2011
    Vineland
    The smoke seemed to be coming heavily from the upper left corner of the LIM gasket.
    Plus, i'm sure it was leaking oil as well.
  8. #8 Re: Losing coolant IMMEDIATELY after topping off radiator!! HELP!!
    Well.. something to consider when you go in. Plug the coolant ports so you can't have an issue with the UIM after that.
  1. grand Prix losing coolant while off
    By Noure in forum General Grand Prix Discussion
    Last Post: 04-08-2013, 12:25 PM
  2. Losing coolant but no leaks?!?!?
    By raverockstar in forum General Grand Prix Discussion
    Last Post: 12-20-2012, 09:08 PM
  3. '00 GT Losing oil and coolant + overheating
    By famous556 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-21-2012, 02:16 AM
  4. Losing coolant
    By MyPrixGT06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-17-2011, 07:18 AM
  5. Losing Coolant from Overflow tank
    By Suaveat69 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-12-2010, 10:00 PM
