Thread: 97 pontiac prix keeps missfiring
Page 1 of 3 123 LastLast
Results 1 to 20 of 51
  1. #1 97 pontiac prix keeps missfiring
    SE Level Member ssiebor14's Avatar
    May 2013
    Biglerville
    My Pontiac keeps miss firing I put brand new spark plugs in it, all have fire, coil pack still has fire and the wires have fire. When I start it it misses but starts which causes the engine to jump or knock. I tried to read it from codes with and obd2 but won't read. I don't know what to do.. please help
  2. #2 Re: 97 pontiac prix keeps missfiring
    May 2013
    Biglerville
    I forgot to say this, when I turn it on and stand near the middle of the car it sounds like there's only half the amount of air coming out of the exhaust and the rpms won't go over 4g I tested to see if it'd redline or max out.. no dice.
  3. #3 Re: 97 pontiac prix keeps missfiring
    It's not supposed to redline in park. It has a rev limiter at 4k. Get a scanner that read live data and see where your misfire is at.
  4. #4 Re: 97 pontiac prix keeps missfiring
    May 2013
    Biglerville
    Can't even do that. Someone cut the wires from the obd port in my car. I can't even rewire it. I just don't understand what'd it be. I seafoamed it too. I let it run an easy 10 mins and still keeps misfiring
  5. #5 Re: 97 pontiac prix keeps missfiring
    Plug order is wrong maybe?
    Bad ICM?
  6. #6 Re: 97 pontiac prix keeps missfiring
    May 2013
    Biglerville
    What's icm I think the plug order is in order have to check it though. Other than that could it be a fuel injector?
  7. #7 Re: 97 pontiac prix keeps missfiring
    Ignition control module, its what the coil packs sit on.
    Plugs are 135 front and 246 rear, going from passenger side to drivers side.
  8. #8 Re: 97 pontiac prix keeps missfiring
    icm is under the coil packs.
    my vote is clogged cat.
  9. #9 Re: 97 pontiac prix keeps missfiring
    Could be right. Why the hell would someone cut the wires for the OBDII port?
  10. #10 Re: 97 pontiac prix keeps missfiring
    May 2013
    Biglerville
    If it's a clogged cat that means I need to get a new one right?
  11. #11 Re: 97 pontiac prix keeps missfiring
    May 2013
    Biglerville
    I don't know that pissed me off though
  12. #12 Re: 97 pontiac prix keeps missfiring
    Yeah, easiest way to see if the cat is clogged is to pull the front 02 sensor out of the rear manifold.
  13. #13 Re: 97 pontiac prix keeps missfiring
    May 2013
    Biglerville
    Ima have to do that. I'm pissed though the car was fine before I got off work. Turned it on after that and it just started misfiring after I pulled a uturn
  14. #14 Re: 97 pontiac prix keeps missfiring
    if your sure the plug wires are on right, and the exhaust is weak out the tail pipes, and the engine dont have any power when driving it, ( may have been slowly getting worse) now it will barely run?
    you can pull the o2 sensor out of the manifold, fire it up, if it runs a bit better the cats clogged, also bang on it, see if it rattles inside it. or if it glows red while driving it. its clogged up.
    clogged cat will also cause a misfire, and make the cel flash when flooring it.
  15. #15 Re: 97 pontiac prix keeps missfiring
    May 2013
    Biglerville
    If the cats clogged do I get another? And yesiI'm sure I can stand beside it and the exhaust will sound like it's trying to push air out but can barely get enough out
  16. #16 Re: 97 pontiac prix keeps missfiring
    Cut it out and weld in a piece of straight pipe, unless you have emissions testing.
  17. #17 Re: 97 pontiac prix keeps missfiring
    May 2013
    Biglerville
    That is possible
  18. #18 Re: 97 pontiac prix keeps missfiring
    Cutting it out or emissions testing?
  19. #19 Re: 97 pontiac prix keeps missfiring
    May 2013
    Biglerville
    Cutting it out.. I'll consider it but then I also have to wait till I get inspected first
  20. #20 Re: 97 pontiac prix keeps missfiring
    Um if the wires are cut to your OBDII port they might fail you just fyi. If they test that way anyway.
  1. 1999 pontiac grand prix gt trailer hitch onto 2008 pontiac g5 gt ?
    By thomasd2010 in forum General Grand Prix Discussion
    Last Post: 02-17-2013, 11:47 AM
  2. Missfiring Issue
    By Enzo354 in forum General Tech Discussion
    Last Post: 05-22-2011, 01:40 AM
  3. New member and first time Pontiac Grand Prix owner (first pontiac ever)
    By Lexiconix in forum Introductions/Noob Questions
    Last Post: 11-10-2010, 09:45 PM
