Thread: engine cranked over until battery went dead, wouldn't start
Results 1 to 18 of 18
  1. #1 engine cranked over until battery went dead, wouldn't start
    SE Level Member twillroth's Avatar
    MN
    Hey all,
    My '02 GT has been starting fairly hard for a little while now. When the engine is cold, or its been sitting awhile, it will crank for 4-5 seconds before it fires. Once it starts, it runs fine and I can shut it off and turn it back on no problem.
    Jump forward to this morning. I've been running storm work in eastern Minnesota and western Wisconsin, so the car has been sitting a few days. I get to the shop this morning, park the truck, and go to start the car and it cranks over but never fires. I ran the battery down trying to get it to start, put some cables on it, and ended up giving it a sip of ether to get it to fire. Once it started it ran fine, has been running fine on the way home.
    I've also noticed a slight loss in power in the upper RPM's, like in a passing situation. Sometimes it'll hesitate and then won't shift up unless I let off a little.
    Any idea what this could be? My buddy thinks possibly the fuel pressure regulator...?
    Thanks,
  2. #2 Re: engine cranked over until battery went dead, wouldn't start
    could be the fuel pressure regulator, seen them do the start then stall, then run, first thing in the morning.
    could also be a real dirty throttle body, or fuel pump on its way out. do you hear the pump whine when the key is first turned? not cranked, just turn to run, listen for the whine, its the pump priming the lines. also check the fuel rail for pressure, theres a valve on the rail, uncap it, push the center of it, see if gas shoots out, watch your eyes, it will spray out all over. rag over the valve is a good idea.
  3. #3 Re: engine cranked over until battery went dead, wouldn't start
    MN
    Do you hear the pump whine when the key is first turned?
    Yeah, I can hear the pump run for a couple seconds when I turn the ignition on.
    Sent from my iPad using Tapatalk HD
  4. #4 Re: engine cranked over until battery went dead, wouldn't start
    MN
    Yeah, the first thing I checked is that valve...it did spray out. When I get a minute I'll go turn the key over and see if I can hear the fuel pump priming.
    It has, in the past, started, stalled, then started hard. Once it's running, it idles and runs fine.
    Thanks for the input, it's very much appreciated!
  5. #5 Re: engine cranked over until battery went dead, wouldn't start
    Banned
    Jan 2013
    the bandwagon follower aka noobiee
    had a friend with same issue was the ignition switch where u install the key something was broken that might be it
  6. #6 Re: engine cranked over until battery went dead, wouldn't start
    MN
    Right on. Now comes the process of elimination.
  7. #7 Re: engine cranked over until battery went dead, wouldn't start
    you can rent, well free rental i call it, cause they refund you your money when you bring back the tools, or buy a fuel pressure gauge, hook it up see what pressure you get when you first turn the key, then fire it up, if it stalls see if it lost fuel pressure.
  8. #8 Re: engine cranked over until battery went dead, wouldn't start
    MN
    Sounds good. I'll pick one up when I get a chance.
    What should the pressures be?
  9. #9 Re: engine cranked over until battery went dead, wouldn't start
    over 40 psi iirc. under 40 they have a hard time starting. so ive read here.
  10. #10 Re: engine cranked over until battery went dead, wouldn't start
    Sounds like a FPR to me.
  11. #11 Re: engine cranked over until battery went dead, wouldn't start
    MN
    Well, I couldn't get a tester at the local parts store, so I took a chance and bought a new FPR. Easy replacement, except for the snap ring. Man, what a pain to get back in. Apparently the snap ring pliers I purchased were junk. I've used many sets of em, but I ended up breaking a few of the pins. Don't know why, they just kept breaking when I compressed the ring. Probably just a POS tool. Anyway, I replaced the FPR and also replaced the plugs and wires. All said and done, I turned the key and it started right up. However, I'd started it before I changed the FPR to move it around in my driveway, so not sure if it's truly fixed. Tomorrow morning will be the test. That's when it usually acts up; that first cold start. Thanks again for all the advice guys!
  12. #12 Re: engine cranked over until battery went dead, wouldn't start
    MN
    One more thing; when I took the boots off the coils, a couple of the contacts were extremely corroded/dirty. What looked like rust literally spilled out/off of the boot and coil. I don't get misfire codes or have any other problems that could be caused by misfires. Only 2 out of the 6 were corroded like that. I want to say it was #'s 3 and 5 cylinders, but I could be wrong. I'd have to look again. Normal?
  13. #13 Re: engine cranked over until battery went dead, wouldn't start
    old wires do that, corrode in the boot. the tune up its self could have been the fix, either way lets hope it fires up and stays running in the morning.
  14. #14 Re: engine cranked over until battery went dead, wouldn't start
    MN
    Good news; the old girl popped off pretty much right away this morning. I'll check the WOT response later, but hopefully this was the cure.
    Now to dive into the LCA's...
    Thanks a bunch guys!
  15. #15 Re: engine cranked over until battery went dead, wouldn't start
    SE Level Member Paintball0027's Avatar
    Jul 2010
    Michigan
    I'm having a similar issue.
    My car say while I was on vacation for about 2 weeks. Apparently we got a huge ice/freezing rain storm while I was gone. Came home and the car wouldn't crank. The battery was dead. So I charge the battery up, and then go to crank it and it cranks forever. No start, just keeps cranking.
    I can hear the fuel pump priming the lines when I turn the key.
    I changed the fuel filter because I thought maybe that was clogged or something. This didn't help.
    I checked the fuel pressure by just pressing the button on the fuel rail, and no fuel shot out.
    Any ideas? The car will crank all day, but no start. It was running just fine before I left for vacation.
    2007 Pontiac Grand Prix GXP - ZZP exhaust,1999 Pontiac Grand Prix GT -Falken Cinturato 828 tires,GMPP performance handling kit,oversized front sway bar, front strut tower brace, tubular trailing arms, spectre cold air, 180* drilled thermostat, ZZP Racing transmission with 3.29 gears, 4th gear hardened shaft, shortened dog bones.
  16. #16 Re: engine cranked over until battery went dead, wouldn't start
    Canada
    If the fuel pump is working as you believe it to be, then u should have some pressure at the rails.....did you change the fuel filter? (might be clogged) and I know it is prolly a stupid question but is the car out of gas? Also I would spray some gas in the throttle body and see if it starts when you do that.
  17. #17 Re: engine cranked over until battery went dead, wouldn't start
    SE Level Member chatbreaker's Avatar
    Mar 2014
    midwest
    Fuel, Air, Spark. Engines need these three things, it's simple enough in theory, but sometimes it can be a pain to track down which of the three is the issue.
    Air is typically not a problem, unless you have an EXTREMELY dirty air filter, or some form of critter got into the air box and built a nest on the outside of the air filter.
    Fuel can be a number of things, starting from the simplest to the most difficult to check, I'd do the following:
    Turn the key on, and listen for the fuel pump. If the car doesn't start right away, turn the key off and back on, then let the pump run until it stops, then crank it. If it takes a few seconds to build up to pressure, it may be a faulty fuel pump/sender unit, or a clogged fuel filter.
    If the pump seems to build up pressure quickly, but the car won't start, it may be a bad fuel pressure regulator or bad injectors. The problem may also lie in the fuel injector wiring, but this is very unlikely. To determine fuel pressure regulator/fuel injector issues, you can buy/rent a fuel pressure gauge, and see what the fuel pressure is at the fuel rail. To check for power to the injectors, I would recommend a noid light set - Harbor freight has them, I think they're kind of pricey, but I have never bought one so I don't recall. A noid light set will plug into the injector wires and light up as you crank the engine over, to show whether or not voltage is going to that particular injector. Test them one at a time.
    Spark can be another issue which would cause a hard start - If you have a weak coil/coils, improperly gapped spark plugs, or corroded connectors, 12.6V from the battery may not be enough to get the engine started, but it will run okay at 14.4V from the alternator once the engine is running. To check for spark, you should invest in a spark plug tester, it's a fairly cheap tool and quite effective, especially on the 3.8L engines where the coils are right in front. Disconnect one wire at a time, and hook the spark plug tester in-line with the wire. Crank the engine over and look to make sure the light bulb lights up. Repeat for each of the 6 wires. If you find one that doesn't light up, or if you notice corrosion on the inside of the spark plug wire boots or on the coil, clean it first, then try starting the vehicle.
    Spark is also controlled by various sensors on the engine, which tell the ignition system when to fire. It is possible you have a faulty sensor somewhere, and it may not be reading the correct spark timing until the engine is running. Another possible cause is the ignition module itself, which can usually be tested by auto parts stores (IIRC) Advance Auto Parts or Autozone can test these free of charge.
    This is just a bit of the information I remember from my college days as an automotive technology student, however I haven't worked in the automotive industry since the local iron foundry pays better ^_^. If anyone notices any misinformation in this post, please let me know and I'll change it ASAP.
  18. #18 Re: engine cranked over until battery went dead, wouldn't start
    Mar 2014
    midwest
    Also, it's not a good idea to crank an engine over for more than 10 seconds at a time, as it can (and eventually will) burn out your starter. If it doesn't start within 5 seconds of cranking, it's typically time to start looking for issues.
  1. Help battery dead but other issues are concerning
    By 87IROCZOWNER69 in forum General Tech Discussion
    Last Post: 02-06-2012, 09:22 AM
  2. How to get a dead battery out
    By sabarrett in forum General Tech Discussion
    Last Post: 02-19-2011, 07:39 AM
  3. Battery going dead?
    By 90oddz in forum General Tech Discussion
    Last Post: 11-06-2010, 06:54 PM
  4. Battery Dead.. Perhaps from the AMP?
    By Supercharged03GTP in forum Audio, Security & Visual Electronics
    Last Post: 10-02-2009, 11:15 AM
  5. Wouldn't Start
    By GTPluv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-02-2008, 09:27 PM
